Author Topic: Octavia  (Read 3385 times)
Offline terryecosse
Octavia
« on: December 04, 2021, 10:05:21 AM »
 Thinking of buying a Skoda ,where can I buy a twin tank system and get it fitted, just outside Edinburgh. All help appreciated,Terry. Other problem is the merc 250td turbo isn’t working, I was told to clean it with mr muscle,just wondering if this would work?
Re: Octavia
« Reply #1 on: December 04, 2021, 07:39:07 PM »
I run an 02 octavia on bio with no problems. I have also used Mr muscle very successfuly on turbos.
Offline terryecosse
Re: Octavia
« Reply #2 on: December 04, 2021, 08:29:48 PM »
Do you just spray it into the turbo,or do you have to take the turbo off?
Offline terryecosse
Re: Octavia
« Reply #3 on: December 04, 2021, 08:31:34 PM »
I was wanting to run it on 2 tanks straight veg, as I’ve stopped making bio
Re: Octavia
« Reply #4 on: December 05, 2021, 11:36:26 PM »
what year Octavia?
I added a heat exchanger and bigger fuel lines to my mates, ran it on 100% veg after that
told him to put £10 of diesel in with each tank full in the winter
Re: Octavia
« Reply #5 on: December 06, 2021, 09:06:30 AM »
I just sprayed it into the turbo exhaust side. Needed to fix a sticking dump valve. There was an on line description but havent needed it for some years. If it is easily removed the I would remove and do a thorough clean on the bench.
Offline terryecosse
Re: Octavia
« Reply #6 on: December 06, 2021, 10:24:23 AM »
The Octavia is 2008 automatic, will try spraying mr muscle into turbo if it has to come off will wait till better weather. Thanks for the help,Terry.
Offline terryecosse
Re: Octavia
« Reply #7 on: December 06, 2021, 05:07:25 PM »
Thanks for the online advice,have looked at a few videos,went to E.C.P. But they didn’t have a turbo cleaner,will try Halfords.
