Author Topic: Graham Lammins set up.  (Read 5577 times)
Offline DavidA
« on: November 02, 2021, 08:38:58 PM »
(Apologies to Graham if I spelt his name incorrectly)
Is anyone here using Graham's reactor set up ?
It looks very business like, and not too difficult to make.
Dave.
Re: Graham Lammins set up.
« Reply #1 on: November 02, 2021, 10:02:16 PM »
I've made the occasional GL set up with a couple of updates as some on here might remember.
Graham's design is without doubt the best way to go.
Offline DavidA
« Reply #2 on: November 03, 2021, 11:46:16 AM »
Can you point me to the updates ?
Cheers,
Dave.
« Reply #3 on: November 03, 2021, 12:10:05 PM »
Without getting into too much detail and not wanting all out war between two 'oldies' on the forum. There are two sides to every story.
I have never been a GL processor person. Too complicated and IMO responsible for poor bio very often amongst newcomers.
Offline DavidA
« Reply #4 on: November 03, 2021, 12:32:15 PM »
I've never used any kind of reactor other than a 20 Litre drum. It works, but is very labour intensive (Makes your arms ache).
What do you see as the main cause of batch failure with GL's set up ?
« Reply #5 on: November 03, 2021, 01:23:51 PM »
If its a choice between a 20 litre drum and a gl proc I would prefer the 20 litre method all day long!
I've use the drum method lots of times, 3x 10 seconds mixings works as well as a pump for much longer and all done at ambient.
I will post more details when I pm. I know a lot on here love gl's and my views are contra to the ones most people have but just what I have found over the years.
« Reply #6 on: November 03, 2021, 05:41:10 PM »
Lots of info on GL processors along wit others on the wiki.  Check it out if you haven't already.
The wiki hasn't been updated for some time.  Notable missing methods are dgs's ambient processing and minimal, intermittent mixing on which you should find forum threads with a bit of searching.
Offline DavidA
« Reply #7 on: November 03, 2021, 07:29:45 PM »
Thanks for that, Julian.  I'll have a look around.
« Reply #8 on: November 04, 2021, 11:21:22 AM »
I've been using the GL design for over a decade.  But TBH you do not need the venturi to condense methanol, just heating in an enclosed system pushes the vapour through the condenser.  I only really use the venturi to mix in the methoxide.
Offline DavidA
« Reply #9 on: November 04, 2021, 01:14:33 PM »
Isn't the main purpose of the venturi to mix the meth in with the oil at the beginning of the process ?
« Reply #10 on: November 04, 2021, 01:38:46 PM »
The purpose of the venturi is to create the vacuum to allow the methoxide to be drawn safely into the flow of oil.
Offline DavidA
« Reply #11 on: November 04, 2021, 03:35:32 PM »
Pretty much what I meant; but put more elegantly.
Also useful for adding the 5% wash , if used.
« Reply #12 on: November 04, 2021, 03:41:42 PM »
Indeed...and for sucking back in any samples taken during the mix :)
« Reply #13 on: November 05, 2021, 10:34:23 AM »
Yes but if you look at his state diagram valve V7 is also open for methanol recovery
http://www.graham-laming.com/bd/ecosystem/state_diagram_new.htm
I can see the thinking, to circulate the vapours through the condenser - however this is not necessary.
