Author Topic: Search button  (Read 2589 times)
Search button
« on: June 28, 2012, 08:04:37 PM »
Is there some secret to using the search  button at the mo? or is it just me as usual?
Re: Search button
« Reply #1 on: June 28, 2012, 08:45:27 PM »
I've just tried it to search for "water" got no results.  Then tried "biodiesel" and got loads, tried "water" again got some results.  I'm not sure what that was all about - have you tried your search twice?  Maybe no-one has ever used it before and it needed to do some database initialisation or something.
Re: Search button
« Reply #2 on: June 28, 2012, 10:02:41 PM »
Seems to work fine for me which is strange because so many things don't at the moment!
Re: Search button
« Reply #3 on: June 28, 2012, 10:18:39 PM »
Seems to be working now on the enter key,nothing if i hover over it, until it comes up search again then i can use the cursor
Anyway i might just as well ask what i was searching for!
Julian - how much crimping would you recommend?
Re: Search button
« Reply #4 on: June 28, 2012, 11:29:52 PM »
At the moment ... none!
Re: Search button
« Reply #5 on: June 29, 2012, 01:36:10 AM »
I can't remember the pitch of the crimps off the top of my head, but the crimped section wants to be as long as possible / practical.  Then you need to work out the length of the straight ends ... basically the "T" length plus a section to connect to.
Then just cut the 22mm pipe to suit.
