Author Topic: Rotary Barrel pump  (Read 1219 times)
Offline thatmusicman
Rotary Barrel pump
« on: January 22, 2021, 02:35:09 PM »
Just went to post on VOD, and shock horror the bandwidth has been exceeded again!
Just after a recommendation for a rotary barrel pump. Are any brands better built than others?
Cheers
Re: Rotary Barrel pump
« Reply #1 on: January 22, 2021, 04:17:12 PM »
I've got a couple of cheap ones and they are so simple that I wouldn't worry about build quality.
One of them has a larger bore pipe and it does seem to pump a bit faster.
Mine seize up if left for any length of time after pumping veg but they're easy to pull apart and clean out.
« Reply #2 on: January 22, 2021, 11:19:03 PM »
I'm with Keef...they are a piece of piss to take apart and clean. I had one for years....incredibly efficient. Not entirely sure what happened to it. Certainly didn't make the transition to my new home.
Offline BANDIT2
« Reply #3 on: January 26, 2021, 10:31:12 AM »
The veg tends to stick the vanes in the rotor if they are left standing. The one I had used a very thin cellophane type gasket to seal the cover, this ripped the first time I stripped it down so I made a new one from a cereal packet. It then decided it didn't want to work anymore, I realized that a close fit between the rotor and the cover was important to create suction, something I removed by using a thicker gasket. Some thin gasket paper sorted it.
I don't use one anymore but I used to play a hot air gun over it whilst frantically wanking the handle if it became gummed up from storage.
