Author Topic: Citroen Relay van fuel pop  (Read 2522 times)
Offline CanidrivE
« on: October 03, 2020, 03:02:10 PM »
Hi guys, that made you look into this ? Tell you what it is, on the other post I said about the fuel gauge,  I have moved the van to do some work on it and it involved stripping down the body, when I took the fuel filler cap off I got a "POP" don't know if it was air going in, or rushing out.
I have looked at the pipes coming from the tank 2 of them and just inside the inner wing they come together in an air tight way.  I can not see how the tank is suppose to take a breath  in or out ?
If any one knows about this or knows some one who has a Citroen, Fait, or Peugeot van could you please ask
Dave
Re: Citroen Relay van fuel pop
« Reply #1 on: October 03, 2020, 09:40:40 PM »
Have you checked the fuel cap isn't gunked up?
« Reply #2 on: October 06, 2020, 11:19:36 AM »
Caps sometimes have a small hole to vent the tank.  If in doubt leave it loosely attached to let air in, and see if that helps with any running issues.
