Author Topic: 2006 Citroen C5 1.6 hdi running on Biodiesel  (Read 5327 times)
Offline Mark2256
« on: May 09, 2019, 10:59:19 AM »
Hi All not been on the forum for a while, I have been building my bio plant, I have now completed my first batch (100 litres). I am now running my car on a 40 litres biodiesel and 20 litres Diesel mix to see how it runs and all appears good.
I took the car down to my MOT man yesterday for an emissions test?
Boston 1 is the test result from the previous MOT.
Boston 2 is the test result from yesterday.
« Last Edit: May 09, 2019, 11:06:25 AM by Mark2256 »
Offline RichardP
Re: 2006 Citroen C5 1.6 hdi running on Biodiesel
« Reply #1 on: May 09, 2019, 09:59:56 PM »
Looks like a good reduction from what I can make out. Good result.
Offline Mark2256
« Reply #2 on: May 10, 2019, 10:16:50 AM »
Thank You For the reply,
I am hoping to run p100 and would like to see the mean opacity come down to around 0.0?
« Reply #3 on: May 10, 2019, 05:09:11 PM »
Hi Mark, have a look at some of the Smoke Density readings we got with the simple methanol/water injection here.
http://www.biopowered.co.uk/forum/index.php/topic,3107.0.html
« Reply #4 on: May 12, 2019, 12:08:47 AM »
Good result. You can still get some soot with biodiesel so don't set your expectations too high.
One word of caution would be blending biodiesel and fossil fuels - sometimes this can cause dropout in the fuel, only is best to mix outside the tank and stand for a while - if you don't want a blocked fuel filter. Obviously not an issue with b100. Most likely not a problem anyway but it's worth mentioning just in case.
Offline Mark2256
« Reply #5 on: November 15, 2019, 02:42:10 PM »
Hi All not been on for a while so here's an update on my car running B100. I took the car in for is new MOT last month and emissions test showed mean opacity value of 0.13 {m-1] I don't think I will get any better than this.
« Reply #6 on: November 16, 2019, 12:16:05 AM »
That's pretty amazing. :)
