Author Topic: It seems Ive missed a lot???  (Read 2034 times)
Offline oojimmyflip
« on: May 11, 2012, 06:37:32 PM »
Hello everyone,
I haven;t been on the veggy site for ages and now I cannot even find it let alone get on it there seems to be a server error of some kind.
I googled it again and found this site recognized the names rotary& K.H and registered.
my Mk2 Xantia decided it didnt like veg oil anymore and the ECU light kept comming on retarding the engines ignition and making her overheat, I am currently running on 50/50 filtered wvo and diesel expensive I know but Ive really no option if I want to keep the ecu light turned off.
I think much of this is because I really need new filter system 10" filters as I have been cleanning them in my home made cleaner for quite a long time now, thye must be loosing their effectivness.
does anybody know where to buy filters these days please?
also which subject or part of this forum do I go to -to catch up on what i have apparently missed.
good to see that most people are still around, I started to panic a bit before I found this site.
regards Nigel.
Citroen Xantia S2 running on filtered wvo approxamately 4 years until ECU played up now running 50/50 dino/veg
Re: It seems Ive missed a lot???
« Reply #1 on: May 11, 2012, 06:57:33 PM »
Evening Nigel
I think Phil Davenport is still one of the cheapest for filters
http://www.biodieselfilters.co.uk
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=30588&page=1#pid347889
If your having trouble getting on the VOD maybe have a word with RM as hes a godlike admin on there and should be able to sort it
Not sure how you catch up on here but the forum has only recently been expanded so there are a few empty categories
« Reply #2 on: May 11, 2012, 09:46:03 PM »
Pooh hello chap :)
Offline oojimmyflip
« Reply #3 on: May 12, 2012, 07:51:17 PM »
Managed to get onto the VOD finally last night I followed a link on this site and managed to log on
whenever I used to format my C: drive before I used to type www.vegetableoildiesel.co.uk/forum
to get back to the Vod but this time it didnt work at all. (it seems that the link above actually works now that's a little weird) >:( >:( >:(
Im glad I found you all anyway because without you all I'd almost certainly be destitute and pennyless by now as you can see by the avatar things have got so bad Ive purchased a 2cv to restore. ::)
thanks for the info on the filters source K.H and hello Tony. ;)
cheers Nigel.
« Last Edit: May 12, 2012, 07:53:42 PM by oojimmyflip »
