Author Topic: A quick way to increase processing capacity  (Read 6319 times)
« on: January 24, 2017, 12:22:56 AM »
My processor is a max capacity of 220 litres. This means if I add my usual 24.5 litres of methoxide for S1 to my pre glyc treated oil I can only process about 190 litres of oil. During Winter, when I use KOH only methoxide the 190 litres of oil will leave me with about 185 litres of finished bio.
To give me more like 205 litres of finished bio I prepare a Dr Pepper type process in a cubie, using the same chemical proportions as the processor.
After S1 glycerol has settled for a few hours I remove it (leaving spare capacity in the processor) and pour in the entire contents of the Dr Pepper cubie. I then leave to settle until the next day and then remove all the settled glycerol again.
As long as this leaves me about 5 litres capacity in the processor for S2 methoxide then this gives me well over 200 litres of finished bio.
It is an easy thing to do and means that each process is done around 3 days less often.
« Last Edit: January 24, 2017, 10:30:05 AM by dgs »
Re: A quick way to increase processing capacity
« Reply #1 on: January 24, 2017, 12:24:25 PM »
Why not use an IBC as your reactor and do really big batches?
« Reply #2 on: January 24, 2017, 08:47:53 PM »
y
you trying to off load some dodgy eductors?
« Reply #3 on: January 24, 2017, 08:54:46 PM »
y
Ha, a bit too big for me, an IBC. The idea was to just increase the production in what I already had.
« Last Edit: January 25, 2017, 11:56:02 PM by dgs »
Offline DavidShinn
« Reply #4 on: May 17, 2017, 10:51:56 AM »
Hi Dave,
Just read this post and what a good idea. Increasing the batch size after the S1 process by topping up with a mini batch processed in a cubie. Definitely going to try that next time..
By the way. Just completed a process at 20C with no problems at all. One big advantage of doing ambient  reactions is that the methanol stays in the mix rather than flashing off and condensing on the underside of the processor lid.
Cheers
David
« Reply #5 on: May 17, 2017, 01:32:32 PM »
My method is -
Brim processor with veg and glyc
Glyc wash
Drain glyc, and a bit of veg (which is saved), so there's enough room for my s1 methoxide.
Drain glyc, put back in initial veg
90/10
S2
Not quite the same as you, but another way to max out things.  The percentage of veg that i re-add is small enough that it does not mess with the calculations too much - i generally OD s2 by 10% anyhow, to push for complete conversion (S2 chems are cheap, as youre not using much of them anyhow)
I use the meth-limiting process - 10% of the veg volume on each stage.  Seems to work out ok.
« Reply #6 on: May 17, 2017, 03:36:58 PM »
Yes, this way works really well, yours too Julian.
Writing this from my hospital bed, just had the 1st of my knee.  Joints replaced, whereas most of you have a cartilage between your bones, I have a chrome cobalt/nylon sandwich,
« Reply #7 on: May 17, 2017, 08:20:16 PM »
When ever I wanted to increase batch volume I just built a bigger reactor, problem solved.
« Reply #8 on: May 17, 2017, 11:19:26 PM »
That was my plan about three years ago ... still haven't got round to it!
Offline DavidShinn
« Reply #9 on: May 18, 2017, 12:04:42 AM »
Hi Dave
I hope it's all gone well and you make a quick recovery. Will you be in long? Are you up for a biochat if I visit you? Please take care.
 David
« Reply #10 on: May 18, 2017, 01:23:51 AM »
Hi Dave
 David
Dave, I missed that bit in your post ... a very swift and complete recovery.
« Reply #11 on: May 18, 2017, 12:08:42 PM »
Thanks for the replys. I don't quite know whats happening here, I posted yesterday from the hospital but the post has now gone. Anyway I'm back home now, complete with my new chrome cobalt reconstructed knee.
Ah, I see the post , maybe all the anesthetic still hasn't worn off yet! David, Phone me anytime.
« Last Edit: May 18, 2017, 12:12:09 PM by dgs »
« Reply #12 on: May 18, 2017, 01:23:14 PM »
Very nice, did they say how long the replacement will last?  Sounds like a neat bit of engineering at any rate, I guess it is shaped to your bones?
« Reply #13 on: May 18, 2017, 07:47:43 PM »
Hi Tony, I think it is a minimum of 10 years depending on how I look after it (for instance no jogging or really active sports)  As far as I know the consultant has a variety of shapes to choose from. As the joint has laid down new bone to replace the cartilage, this has been removed and trimmed to suit the metal cap. the cap has a spike to locate it down the bone which is hammered into place.
I had the op under a Spinal, the anaesthetist said I could have a small sedative just to make me half asleep. He must have thought I looked a little nervous so I was totally asleep.
« Last Edit: May 18, 2017, 07:49:50 PM by dgs »
Offline RichardP
« Reply #14 on: May 19, 2017, 11:05:14 AM »
I can't imagine having a spinal for major surgery like that. I've had several orthopedic ops all under general anaesthetic, would never have them otherwise as orthopedic op are basically all saws, hammers, chisels and drills, a bit like my garage.
Hope you have a quick recovery.
