Author Topic: login !  (Read 3244 times)
login !
« on: December 08, 2016, 10:06:56 AM »
HELP why do I have to login everytime I come here, I never used to have to.
Re: login !
« Reply #1 on: December 08, 2016, 10:11:06 AM »
Hiya, maybe an old cookies thing with the site move.  If you clear your cookies, then next time you login, instead of entering your name and password in the top right corner, click the "login" link and tick "always stay logged in" you should be good to go.
Re: login !
« Reply #2 on: December 08, 2016, 11:09:58 AM »
It's the same for most of us since the site move I think.
I find that although it says I'm not logged in, I am actually half logged in and all I need to do is click the login button without entering any details and I become fully logged in.
A bit of a pain in the arse but I can't find a way round it.
Re: login !
« Reply #3 on: December 08, 2016, 11:27:31 AM »
when I first come to the site from my bookmark, the login box is there in the top right wanting username/password etc..
but as soon as I click a link, I'm already logged in
at a guess, we're already logged in, and shoring the login box is an error ?
Re: login !
« Reply #4 on: December 08, 2016, 11:31:28 AM »
We're only half logged in as we can't see the threads that you need to be logged in to view until after you click the login button.
Re: login !
« Reply #5 on: December 08, 2016, 01:21:50 PM »
It's similar on the wiki ,,, no one can edit or add to it.
Tony ... you mentioned just after the move that the issues were most likely caused by the current host using a different type of server.   Would a host change to the right type of server cure the problems if we reverse the changes my mate made to make the wiki visible?
Offline terryecosse
Re: login !
« Reply #6 on: December 08, 2016, 04:31:59 PM »
I'm having the same problem having to log in every time.
Re: login !
« Reply #7 on: December 08, 2016, 04:54:40 PM »
I seem ok, no problems
Re: login !
« Reply #8 on: December 08, 2016, 05:03:11 PM »
Just been experimenting. I half log out, if I close the site while logged in.
Hit the LOGIN button, and I'm logged right back in again.
Even if I log out properly, then hit the LOGIN button, go the the LOGIN page, log in, and check the KEEP ME LOGGED IN box, I still half log out when I leave the site.
Re: login !
« Reply #9 on: December 08, 2016, 07:09:44 PM »
I've changed the settings as advised here - please let me know if this helps
http://www.simplemachines.org/community/index.php?topic=226336.0
Re: login !
« Reply #10 on: December 08, 2016, 09:06:48 PM »
Now it is fully logging me out when I leave the site.
Tried checking the "Keep me logged in" box, still fully logging me out.
Re: login !
« Reply #11 on: December 08, 2016, 10:40:03 PM »
Might have found the issue - we all use www.biopowered.co.uk not biopowered.co.uk - I've changed the settings to match this so hopefully that will help!
Re: login !
« Reply #12 on: December 09, 2016, 09:45:41 AM »
Seems to work for me  ;D
Thanks Tony, it was driving me mad!
Re: login !
« Reply #13 on: December 09, 2016, 09:08:19 PM »
Yup, nice one, that appears to be working.
