Author Topic: Flash evaporator?  (Read 12027 times)
Flash evaporator?
« on: May 06, 2012, 09:47:17 PM »
Whats the view on this? is it a non flash squirrel or nearer the real thing?
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/159605551/m/352100169/p/1
Re: Flash evaporator?
« Reply #1 on: May 06, 2012, 10:46:14 PM »
That sounds exactly how I'd expect a proper flash evaporator to work
« Reply #2 on: May 07, 2012, 07:49:40 AM »
Thanks Tony,i shall have another read then,is it a similar design to what you intend to make?
« Reply #3 on: May 07, 2012, 10:58:00 AM »
Similar but mine will be multi-pass as it won't be at such high pressure (his is at 6.0 bar and over).
For water really it'll be a glorified diffuser, but with Methanol it should properly flash.
« Reply #4 on: September 08, 2012, 08:30:05 PM »
Any progress on this Tony?
« Reply #5 on: September 08, 2012, 08:42:27 PM »
Got it all planned and done the calcs, will post them here when I'm back home. Will do the welding on that last though when I'm in the swing of it as it'll need to take 4 bar without leaking!
« Reply #6 on: September 09, 2012, 08:38:23 AM »
I should be starting to build my new evaporator in the next few week's , just getting some of the main bit's together. My plan is to buid something to de-meth in a single pass. When I have this working I'm then going to try adding extra heat to the heat exchange and extra vacuume to the vac vessel and see if it's possible to vac distill the bio. It all works in my head but I'm sure there will be headache's along the way.
My plan is a small amount in a constant flow.
I will update when things start getting put together
« Reply #7 on: September 09, 2012, 12:43:26 PM »
I posted this ...
on the VOD a while back in this thread ... http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=19674
I thought it was a reasonable idea, but it had already been thought of and wouldn't work according to the experts.
Ho, Hum.
« Reply #8 on: September 09, 2012, 02:38:37 PM »
Hi Julian
I had a read of the thread but cant see any pictures (if there are any).
I think I have a really simple design but trying not to look to much into other designs until mine fails.
Probably the wrong way to go about it but if I go with gut feeling and it doesnt work at least I will know
Cheers
Paul
« Reply #9 on: September 09, 2012, 02:45:27 PM »
Can't see any either,  thought it was because of my phone but perhaps not it seems!
« Reply #10 on: September 09, 2012, 03:23:04 PM »
I can see the pics, no problem.  Just a link to my webspace ... these are the URLs
http://www.palmergroup.co.uk/Bio/short_path_evaporator.jpg
http://www.palmergroup.co.uk/Bio/short_path_evaporator_schematic.jpg
Not sure why others can't, can you see them in the VOD thread?
« Reply #11 on: September 09, 2012, 04:02:53 PM »
No think its a phone thing (iPhone 4s )
« Reply #12 on: September 09, 2012, 04:06:00 PM »
Both links redirect to http://mobilf.com/in.cgi?10 on my mobile (android). Can't see em on VOD either.
« Reply #13 on: September 09, 2012, 04:15:11 PM »
Ah it's Julian's site, it tries to do something clever for mobile browsers but it doesn't work. If you change the browser settings so user agent is ie6 then it works and the pictures appear.
« Reply #14 on: September 09, 2012, 04:25:05 PM »
Very interesting idea Julian. What stops the vacuum sucking bio up from the bio receiver via the bio exit?
