Author Topic: Bio/diesel lubricant properties  (Read 3808 times)
« on: September 02, 2016, 10:04:05 PM »
Currently helping a mate to fix a HPFP on his Tiguan which he's running on Dino Diesel.
We had a jar of diesel and a jar of bio on the bench so I tried sticking a finger in each jar and rubbing finger and thumb together ... I know bio is said to have better lubricant properties than diesel, but the difference was quite remarkable.
If I had a car running a pump at 26,000 psi, I know which fuel I'd use!
Re: Bio/diesel lubricant properties
« Reply #1 on: September 02, 2016, 10:19:35 PM »
Well come on then, which one?
« Reply #2 on: September 03, 2016, 01:25:50 PM »
Pervert!  :o
« Reply #3 on: September 03, 2016, 04:47:44 PM »
Its bloody obvious he is measuring the lubricity it must be the index finger.
« Reply #4 on: September 03, 2016, 09:25:45 PM »
I don't know ... you try and disseminate interesting experiences and all you get is a barrage of abuse!
« Last Edit: September 03, 2016, 11:20:24 PM by Julian »
« Reply #5 on: September 03, 2016, 10:55:52 PM »
Errrrrrrrrrrr!
To decimate is to remove/eliminate 10% of something.
« Reply #6 on: September 03, 2016, 11:24:03 PM »
Errrrrrrrrrrr!
And now the pedants have escaped ... I think you know I meant disseminate.  Spell check error.  My shallowest and most insincere apologies!
« Reply #7 on: September 04, 2016, 01:12:23 AM »
Or was it a deliberate Malapropism?
Offline Soft top
« Reply #8 on: September 04, 2016, 11:54:57 PM »
Errrrrrrrrrrr!
If you remove/eliminate 10% of something. Would the result be omething. ??
« Reply #9 on: September 05, 2016, 12:13:31 AM »
Errrrrrrrrrrr!
You only got yourself to blame when the pedantic old bugger comes back and tells you that's 11.1%
Offline Soft top
« Reply #10 on: September 05, 2016, 07:59:46 AM »
Errrrrrrrrrrr!
11.1%? ows dat den??     something. has 10 characters (including the dot) and I removed one of em.
 Oops, Im being pedantic now...............
« Reply #11 on: September 05, 2016, 09:23:40 AM »
Ah ... the dot!
He'd tell you that's not part of the word.  But for my part I'm more than happy for it to be included.
« Reply #12 on: September 05, 2016, 10:44:15 PM »
If you  include the tittle/glyph (the dot above the I) then removing a single letter would equate to 9.01% there for NOT decimating the word "something".
« Reply #13 on: September 06, 2016, 12:18:15 AM »
... therefore ...
« Reply #14 on: September 06, 2016, 10:50:02 AM »
