Author Topic: Immersion element  (Read 1668 times)
Immersion element
« on: July 11, 2016, 10:18:44 PM »
Brewing a batch today and went to switch the heater on and nothing, checked the fuse and plug wiring, all ok, checked the element wiring, it looked ok, then whilst checking the tightness of the screws to the element wires it suddenly started pissing bio over me!
I grabbed a bucket to catch the leak and then diverted the pump flow to my settling tank and grabbed a couple o cubies and started draining from the bottom of the processor too as I knew with the glyc still present it was more than the settling tank could hold.
Once all was drained I removed the element and found the the thermostat pocket had come away from the base, not very good as I only fitted it in 2005, mind you it was second hand.
That was after having a blockage at the start and I had to remove all the bottom pipework and poke it through and wash it out! I finally finished the batch at 9-30pm, a complete contrast to my last batch where everything went quickly and smoothly.
Now having a nice home brew all grain beer.  ;)
Re: Immersion element
« Reply #1 on: July 12, 2016, 02:32:32 AM »
A well deserved beer by the sound of that one. I had a oil leak last weekend but it was my astra's alternator. They saw fit to put the power steering pump at the back of it. Seal went n pissed oil into the alternator. Only 4 months old. Spent Saturday evening removing it when I got home after a O/T shift then Sun morning assembling it. I was well pissed off. So after doing my oil collection had one of Vince's ciders. Cheers.
« Reply #2 on: July 12, 2016, 04:53:53 PM »
In your nice heated pool I hope.
« Reply #3 on: July 13, 2016, 11:07:50 AM »
i had the same thing happen with the hot water tank. noticed it was a bit damp so checked and discovered the thermopocket was leaking. when i tried to remove the stat it fell off completely. glad it was  a  top fitted heater and not a  bottom one. just turned the cold supply of and drained the first inch of water off. wonder how common that problem is? the heater was about 5 years old,maybe a bit more.
