Author Topic: eblag product description  (Read 1822 times)
« on: May 17, 2016, 09:01:40 PM »
2L3L Common manual watering gardening sprinkler nozzle
Pressure sprayer uses common knowledge at the maximum amount of liquid charged liquid line can be installed, do not exceed the mark.
At the maximum liquid volume, to cheer at 20-30 (Tsubouchi pressure was about this time 4-5 kg / cm) when the maximum liquid volume, generally level with the spout manually from the manual principle 8 cm nebulizer is based on the relationship between the gas flow rate and pressure to work.
When the hand sprayer die on the piston, so that the liquid is inserted in the top of the air flow to accelerate the straw, the pressure decreases and the bottle of liquid above the outside air pressure is equal to atmospheric pressure, so that makes the air above the liquid suction pipe pressure is greater than the pressure at atmospheric pressure strong role in the straw on the drug hydraulic, and then ejected from the front of the gun.
Size: Approx. 17.5x32cm / 6.89x12.6inch
Material: Plastic
I am sure it the right thing you need now.
Don't hesitate, bid now and never miss it. You will receive a package includes as follow.
1 x 2L 3L Adjustable Watering Sprinkler Head
 :o
Re: eblag product description
« Reply #1 on: May 17, 2016, 10:24:09 PM »
I am at a loss the description is so detailed just what is it you do not understand.
The only thing missing is the unit of measurement is it in BTU pascals volts amps or horse power / torque.
« Reply #2 on: May 17, 2016, 10:46:10 PM »
i`m just at a loss to be honest
« Reply #3 on: May 17, 2016, 11:41:50 PM »
Think it did lose something in translation.
« Reply #4 on: May 18, 2016, 12:04:58 AM »
Bloody obvious what it is,  if you can't tell by the finely detailed description I ain't about to tell you.
« Reply #5 on: May 18, 2016, 12:53:51 PM »
that would make a brilliant physics exam question.
« Reply #6 on: May 18, 2016, 03:10:09 PM »
I'll take two.  One for each hand.  Don't cross the streams, through.
Will you be ejecting just dihydrogen monoxide, or mixing in additives for nutrition or, alternatively, destruction?
« Reply #7 on: May 18, 2016, 11:40:19 PM »
i only wanted a squirty bottle... :-\
