Author Topic: jgs yellow pump impeller.  (Read 3632 times)
« on: April 26, 2016, 04:57:23 PM »
Does anyone know if a TAM105 or 120 impeller fits one of jgs's yellow pumps.
There's a possibility one may  need to be replace in the very near future.
Re: jgs yellow pump impeller.
« Reply #1 on: April 26, 2016, 05:45:22 PM »
The yellow 120lpm jgs pump i have is closed impeller.
Did he do smaller ones with open impellers?
« Reply #2 on: April 26, 2016, 06:15:29 PM »
Yes, he did smaller pumps around the 50ltr/min with peripheral turbine type impellers as in the leo and tam105.
« Reply #3 on: April 26, 2016, 11:35:59 PM »
Have a 105 impeller in stock can measure it for you if that will help.
« Reply #4 on: April 27, 2016, 01:13:34 AM »
If you'd be so kind Richard, thanks.
« Reply #5 on: April 27, 2016, 10:04:08 AM »
I have one of the 100lpm ones where the motor has burnt out (it is blue, before he did the yellow ones) you are welcome to it Jim if it is any good to you.
« Reply #6 on: April 27, 2016, 05:13:15 PM »
Impeller dimensions.
Width 60mm Bore 12mm and 6.5mm thick.
Hope this helps.
Richard.
« Reply #7 on: April 27, 2016, 05:47:11 PM »
Hope this helps.
Richard.
Thanks for that.
