Author Topic: Cold water washing....  (Read 5611 times)
Offline Bio-boy
« on: January 19, 2016, 10:36:16 AM »
Does anyone do this or has at least tried it? I'm curious as to the importance of heating the bio prior to washing. Is it really a necessary process or is it an unnecessary use of energy.
Interested to hear your thoughts.
Re: Cold water washing....
« Reply #1 on: January 19, 2016, 02:01:33 PM »
I have done it a few times, even at this time of year, where the bio temperature was <5degs. It's not really a good idea, it will take more washes and increase the chance of an emulsion.
I usually water wash at around the 30deg level. Having said all that the whole washing process mainly depends on the starting level of the soap.
« Reply #2 on: January 19, 2016, 05:22:35 PM »
I mist wash all year round outside, sometimes as soon as the glyc has dropped so still warm, sometimes the next weekend, it all ends up the same temp as the water pretty quickly anyway
Offline RichardP
« Reply #3 on: January 19, 2016, 05:51:34 PM »
I always bubble wash down to ambient temp, which means I'll always have a couple of cold water washes. Doesn't cause any problems washing cold from my experience.
« Reply #4 on: January 19, 2016, 09:39:04 PM »
Unnecessary use of energy IMHO, many years ago when I washed my bio I always used cold water from the tap, hosepipe spray gun on fine mist for the first 5-10L and then slowly open it up to full pressure rain mode.
Offline biobill
« Reply #5 on: January 20, 2016, 03:07:15 AM »
i always use  hot water in my hot bio I say that because as soon as the glyc settle out around 30 mins its washed I just add 20lltrs water to around 160ltrs bio and paddle wash it for 5 mins works great and settles out in 5/10mins
« Reply #6 on: January 20, 2016, 08:25:42 PM »
Water washing seems to improve cold weather performance of bio ref. a load of tests I did on HMPEs and put on the VOD.  So for many years I've water washed using the processor pump.
Since fitting Frankinpump, I've had problems making emulsions (perhaps more accurately had no problem making emulsions), so I add sulfuric acid to the first water wash.
Where I can, I try and wash immediately after processing while the bio is still hot, but I always do so with cold water.  On occasions when the bio's cooled I've noticed no detrimental effect (other than it's easier to make an emulsion).
Offline Bio-boy
« Reply #7 on: January 20, 2016, 10:06:28 PM »
Well I decided to give it a whirl this morning. Having finished the 2nd stage reaction last Sunday I started washing this morning - Bio cold and water cold. What I did notice was that there was a lot more soap present than usual. I only had time for 2 wash cycles so not yet finished the process.
The presence of more soap could be one of two things......either it's the cold wash process or having deviated from my original processing protocol of completing a water wash cycle on completion of the 2nd stage reaction to kill any over reacting and hence excess soap production. I'm going with the latter.
I guess we won't know till I make my next batch.
« Reply #8 on: January 20, 2016, 10:31:56 PM »
Are you pump washing in the processor?
Offline Bio-boy
« Reply #9 on: January 20, 2016, 10:44:36 PM »
Nope. Misting.
« Reply #10 on: January 21, 2016, 12:23:30 AM »
Bio-boy,
The presence of what you think is more soap is possibly mono's, more noticeable because of the lower temperatures. Don't think I'm trying to push my or others methods on to you but when you get clear wash water with misting, it probably wouldn't be clear if you re-washed with your pump or a compressor. Really churning up the bio and water for 20 mins and then having clear wash water is (I have found) the way to guarantee soap levels of 10 to 20ppm and therefore less of other contaminants. (unless like me you end up with insoluble calcium soap in the bio, but thats another story)
« Reply #11 on: January 21, 2016, 12:37:30 AM »
I've noticed since fitting Frankinpump and acid washing, the acid wash and one, possibly two subsequent washes are reasonably clear, the water having a slight bio coloured tint to it.
Further washes usually result in milky water and what looks like a thicker milky interface layer.  I take this as being the start of an emulsion.  If I leave the pump running for more than a couple of minutes an emulsion will result ... it's obvious it's an emulsion because it will break with acid.
If at the point of getting milky wash water, if I add a small quantity of acid to the next wash, the drained water returns to clear.
Does this sound similar to what you're seeing, Dave?
I also suspect that bio that's been emulsified and broken with acid is far more difficult to dry.
« Reply #12 on: January 21, 2016, 01:45:13 AM »
Doesn't adding acid increase the soap? Always seems to, and massively, when I've had to break an emulsion using it.
Offline Bio-boy
« Reply #13 on: January 21, 2016, 07:58:14 AM »
Bio-boy,
Dave, why would using the pump not create an emulsion with the presence of water?
« Reply #14 on: January 21, 2016, 08:46:12 AM »
Not that I've noticed.  Can you make soap with an acid?
