Author Topic: 500 lt tank as a Processor  (Read 50587 times)
Re: 500 lt tank as a Processor
« Reply #75 on: May 12, 2012, 10:50:52 PM »
I wonder if im brave enough to post the build up on the VOD
that isnt the question as you and me know its the negative aspect vod holds aswell as a mixed in price cost
« Reply #76 on: May 12, 2012, 10:53:22 PM »
Ah sod it,i can take the stick,im going in,wish me luck,smoke me a kipper and i will be back for breakfast!
« Reply #77 on: May 12, 2012, 10:56:31 PM »
the alto ego lol brilliant....
« Reply #78 on: May 13, 2012, 02:42:46 AM »
Nice! You're way ahead of me, I only just put the feet on mine let alone pump brackets. Yours is looking good - curious to hear your plans for insulating it!
« Reply #79 on: May 13, 2012, 11:33:30 AM »
Not sure,that will be the last thing i do,now its supposedly summer it shouldnt be urgent,i will probably go for foil bubble wrap as i like the neatness of it
« Reply #80 on: May 13, 2012, 12:56:20 PM »
Just thinking back to your squirting sight tube ... if you are testing on a partially full tank, the effect will be much worse than when running with a full one.  Might not happen when the tank's full.
« Reply #81 on: May 13, 2012, 03:51:25 PM »
could stick and elbow on the top and back into side of tank
« Reply #82 on: May 13, 2012, 06:22:24 PM »
For the record I doubt you need a swept 90 on the discharge side of the pump. Inlet maybe but not the outlet :)
« Reply #83 on: May 13, 2012, 06:43:27 PM »
Surely its a common problem IF you forget to isolate the tube?,the levers there i just have to remember to use it  ;D
But i can guarantee its a problem Tony hasn't got mainly because his sight tube pipe is still in my garage ;D
« Last Edit: May 13, 2012, 06:48:33 PM by K.H »
« Reply #84 on: May 13, 2012, 06:44:24 PM »
No comment on swept 90s ;)
« Last Edit: May 13, 2012, 06:46:04 PM by K.H »
« Reply #85 on: May 13, 2012, 10:04:55 PM »
I've got one and it's "bollocks" ;)
« Reply #86 on: May 14, 2012, 01:04:07 AM »
Not common with me, but then I've not got big manly pipe work running such a height.  I'm sure a lot depends on the tank level.  look at it at two extremes ...
Imagine if the tank were completely full, the pump would just be circulating fluid.  When it stops the flow round the circuit simply ceases and there's no back flow.
With a few mm in the bottom of the tank, you have quite a volume due to 2" pipe work (I bet you'd be surprised how much it is if you work it out) and head due to the height of the pipe, wanting to rush back into the tank.  I'm sure the small bore of the sight tube isn't helping ... I use 22mm acrylic on a much smaller set-up.
I've had a similar thing on a piping system on a ship.  We had a pump in the engine room pumping sea water up to above main deck level (big tanker, so long pipe) and a non return valve just after the pump.  Pipe work would have been around 10".  Idea being as soon as the pump started flow should be available at the top level.  What happened in practice was that when the pump stopped water tried to fall back down the pipe and the NRV slammed shut with such a force it sounded like an explosion.
« Reply #87 on: May 14, 2012, 09:22:21 AM »
While you're adding bits Keith, if you put a second pressure sensor on that trips when the tank is full, you can control the fill pump from it using a SSR so it never overflows the tank.  It's going to take a while to pump cold WVO in and it'd get tedious watching the level slowly rising.
« Reply #88 on: May 14, 2012, 09:44:06 PM »
shouldnt take long with that big pump, would need to up the bore to holding tanks though...
« Reply #89 on: May 14, 2012, 10:03:47 PM »
Its a Stuart Turner that fills the processor RM,bottom right in the pics,mind you with the capacity of the processor the 205 isnt going to overflow it
