Author Topic: 500 lt tank as a Processor  (Read 50542 times)
Re: 500 lt tank as a Processor
« Reply #60 on: May 12, 2012, 10:01:10 PM »
The cap has a hole in it,fed up with switching the pump off and forgetting the sight valve is open,then watching a jet of oil shoot skywards - i use the sight valve to introduce air when dewatering
The big valve on the left needed to be above the take off to the wash tank,took me about 4 hours to spot it,RM about 30 bleedin seconds!
« Reply #61 on: May 12, 2012, 10:07:46 PM »
Got me beat I'm afraid ... not too easy to see minor details from the photos.
Only possible issue I can see is the sight tube seems to be capped off, but knowing you there's a very good reason for that.
yeah i saw that but knowing K's professionalism i didnt want to offend...  :-X
« Reply #62 on: May 12, 2012, 10:09:39 PM »
No missed it completely!
Would a larger diameter tube solve the problem?  I have a funnel on my sight tube and constantly use it for returning samples and 3/27s, back to the processor.  Couldn't do it so easly with such a small tube.
Just one thought with the pump, and I'm not familiar with that design, but might it trap glycerol in the housing?  If so, can you spin the suction pressing 180°?
« Reply #63 on: May 12, 2012, 10:14:01 PM »
how does turning pimp off force a jet out site tube? cant get me head round that?
« Reply #64 on: May 12, 2012, 10:19:47 PM »
Probably hydraulic shock of oil/bio dropping back down the discharge pipe.
A non return valve in the discharge pipe might sort it too.
« Reply #65 on: May 12, 2012, 10:23:46 PM »
good idea - is the pump self priming against not? being a puller not a pusher?
« Reply #66 on: May 12, 2012, 10:24:22 PM »
Only a small amount from whats in the pipework after the isolating valve but the pump has a reverse so i can shoot it back into the processor
« Reply #67 on: May 12, 2012, 10:26:51 PM »
The sight pipe just refills as it normally would but just quickly,its not really an issue the little cap stops it
« Reply #68 on: May 12, 2012, 10:29:32 PM »
may have it? due to the ferocity of the pump and pipe dia, the contents after turn off and the oil returning to level drops fast due to vast volumes of liquid thrown into main tank, so a sort of hydraulic push as brtp states occurs and the only place to go is an open site tube, (a venturi of sorts) how the romans transfered water by GRAVITY up hill! velocity = mass X momentum.
« Reply #69 on: May 12, 2012, 10:31:15 PM »
Spot on,better description than anything i could come up with
« Reply #70 on: May 12, 2012, 10:34:43 PM »
Wa'ss that all about then?
Only pump I know that will, theoretically, pump backward is a Mono, but I don't think even they will do that in practice as the rotor will unscrew on some models.
« Reply #71 on: May 12, 2012, 10:35:48 PM »
Yes, as Keith says, spot testicle on, great description.
« Reply #72 on: May 12, 2012, 10:41:29 PM »
Dont really know,but its good fun messing about
Its the S/S AL50 here
http://www.marcopumps.gr/en/catalog/01-surface/tellarini.html
« Reply #73 on: May 12, 2012, 10:43:57 PM »
 8) i have my moments, sometimes detromental to my well being, but its what makes me human (i make mistakes)
« Reply #74 on: May 12, 2012, 10:45:56 PM »
I wonder if im brave enough to post the build up on the VOD
