Author Topic: Glyc pretreatment, all is forgiven!  (Read 5237 times)
« on: August 06, 2015, 01:33:27 PM »
Hated it when I pre-treated oil with NaOH glyc, but now I'm on KOH I thought I'd give it a whirl.
Normally I heat the oil to 105C to dewater, but this time just I added back the glyc from the last batch, heated to 60C, mixed and settled.
Sure enough the glyc I put in was more than the glyc I got out, and the reaction I did after that completed to clear pass with a single stage.
Might be doing that again then :)
Offline Twenty4Seven
Re: Glyc pretreatment, all is forgiven!
« Reply #1 on: August 06, 2015, 01:50:19 PM »
Why didn't you get on with NaOH glyc Tony? Is it the viscosity?
I found it was very thick and took ages to draw in. Adding hot oil didn't help because it separates out so quickly - so now I just add a litre of watery methanol I happen to have laying around - which does thin it down enough to go in easily.
Nick
« Reply #2 on: August 06, 2015, 02:20:38 PM »
I'm trying to remember, I think it was both the viscosity, and that it set in the pipes quickly when settling.
« Reply #3 on: August 06, 2015, 03:23:08 PM »
It's hard to believe a man like you hasn't done any potassium glyc washing before Tony!
« Reply #4 on: August 06, 2015, 04:35:27 PM »
I've been a sodium man exclusively for years.  But I'm just about coming around to the idea that potassium, despite being more expensive, is considerably easier to work with.  I like being able to leave a batch too!
Batch before last, I dewatered the oil the night before, it had fallen to reaction temp by the morning, so in went the stage 1 potassium methoxide via venturi, and I just turned everything off left it standing static while I went to work.
I got back and it had mostly completed the reaction without any mixing.
Ran the pump for an hour and got back up to temp, and no further reaction took place - first stage had gone as far as it was going to go just by sitting there, fantastic!
Couldn't do that with sodium hydroxide, would spend hours unblocking the pipes...
« Reply #5 on: August 06, 2015, 04:52:30 PM »
Does that mean you are going back to overdosing single stage to completion ?
« Reply #6 on: August 06, 2015, 06:13:44 PM »
If I remember correctly, you used to WBD? Now no need to?
Offline Bio-boy
« Reply #7 on: August 06, 2015, 06:17:06 PM »
Offline Bio-boy
« Reply #10 on: August 18, 2015, 02:23:21 PM »
Stopped doing WBD a fair while ago in favour of http://www.biopowered.co.uk/wiki/Two_stage_methanol_starvation_process
But now I'm on KOH I'm definitely going to give glyc pre-treatment a good run to see how that pans out too.  I guess it works so long as the oil isn't ridiculously wet to start with (some of mine does come in sometimes with free rainwater!)
« Reply #11 on: August 18, 2015, 04:38:53 PM »
Tony, as long as it doesn't have free water present (in which case you need to get rid of it) adding the normal amount of glycerol back in (that the process makes) will result in oil that is <500ppm water.
To make sure the glycerol absorbs as much water as it can you need to mix at
 60degs for 1 hour.
« Reply #12 on: August 22, 2015, 04:57:10 PM »
That's good to know. I've done several batches this way now and getting a clear pass is very easy.  Plus I'm not heating the oil to 105c to get water out with the condenser.
« Reply #13 on: August 22, 2015, 06:40:33 PM »
Thats correct. The 105 degree thing is ok if you are running veg but for bio it's a waste of time, the glyc wash will simply remove the water.
« Reply #14 on: August 22, 2015, 10:44:14 PM »
This is mainly true, however there is a limit to the amount of water the gly can remove.
I suffered with processing wights some time ago, due to the capacity wights have to hold on to water the gly wash just could not remove enough of it.
