Author Topic: Fix Chug's oil burner!  (Read 16132 times)
« on: July 15, 2015, 11:26:08 PM »
I found out why my burner wouldn't stay running at the BBB, it has a burnt out component in the control box, and a replacement box is best part of £100, so I'm looking on fleabay/gumtree etc for another burner, either running and cheapish, or a dirt cheap non runner for the control box.
« Last Edit: July 16, 2015, 10:12:39 PM by Chug »
Re: Fix chug's oil burner!
« Reply #1 on: July 16, 2015, 12:00:30 AM »
That's a shame... Is the burnt component replaceable or is the damage too extensive?
« Reply #2 on: July 16, 2015, 09:06:20 AM »
Jules asked the same question Tony, it probably could be replaced, but I'm crap at solder work on circuit boards, I'll get a picture taken of the burnt out component/circuit board and see what folks think.
« Reply #3 on: July 16, 2015, 09:24:27 AM »
Chug,
Upload the photo, and we can see, but also -
What are you wanting the unit for?  If its going to be attended use, then a lot of the control board could be done away with anyhow.
But its probably repairable - they are way more basic than modern units.
« Reply #4 on: July 16, 2015, 09:34:35 AM »
there is a picture here, its not very clear but its the oblong box shape component on the left hand side, you can just see the melted top of it, I will try and get a better photo later when Mahli is back from work with her better camera.
« Reply #5 on: July 16, 2015, 09:50:44 AM »
It looks like there may be some print on the inner face of it?
If there is (or if there are any markings anywhere on it) try and get a snap of them.
Also, does the control unit itself have a brand / part number?  I have one of those burners, and so does jules, but they all have different variations.
« Reply #6 on: July 16, 2015, 10:14:33 AM »
Split the topic so it has its own thread.
Agreed it would help to have make and model of the burner and PCB if possible.  Looks like it got quite oily, like it would enjoy a good rinse with IPA.
It's not immediately clear what that component is - relay, big capacitor?  May have to wait for Mahli's photo.
« Reply #7 on: July 16, 2015, 01:51:18 PM »
Its an Electro Oil inter 11 burner the control box is Danfoss BH011 057H2011 but its obselete and replaced by
Danfoss BH972.10 which can also be replaced by a later control box but that also needs a new wiring base
Later box = 057H8102 and wiring base = 057H7224
There is also a Satronic version TF830.3 fitted to some burners
« Reply #8 on: July 16, 2015, 02:22:39 PM »
Ill have a look to see whats fitted to mine in a few days.  I cant get to it at the moment, as there's 2 drums of bio just in front of it, but im set to pump that elsewhere shortly.
« Reply #9 on: July 16, 2015, 07:52:58 PM »
Written on the component is this
Rifa
GFF
PME 271 M 647
40/085/58
its almost identical to this
« Reply #10 on: July 16, 2015, 10:09:01 PM »
That is just a big capacitor, data sheet for it here
http://www.farnell.com/datasheets/1943741.pdf
really easy to change too.
One for sale on eBay for less than £4 delivered
http://www.ebay.co.uk/itm/PME271M647K-0-47UF-275VAC-630VDC-EVOX-RIFA-CLASS-X2-CAP-/250914316460?pt=LH_DefaultDomain_3&hash=item3a6ba8a0ac
In fact, by the looks of it, everything on that board is old fashioned and easy to change, no nasty fiddly surface mount stuff
The relay would be a pain to get but as your burner was firing up and running for 10 seconds we can assume that is fine.
I will have a look at the control box on my burner tomorrow to confirm but I suspect it is an easy job. If you want to send it in the post to me I will have a go for you
Re: Fix Chug's oil burner!
« Reply #11 on: July 16, 2015, 10:23:15 PM »
aha, that sounds like good news Jules,
whilst you are having a look at yours....
can you look in the very centre of the board at the little barrel component with just one leg that goes between the big black plastic box and the black box orange solenoid thing, as it just fell apart when I was cleaning the board, so it needs that replacing now too!
Offline Rossey
« Reply #12 on: July 18, 2015, 09:13:01 PM »
Wish I was still working at the pressure washer place I used to fall over these.
Brahma boxes
« Reply #13 on: July 18, 2015, 10:21:28 PM »
Rifa
GFF
PME 271 M 647
40/085/58
That is a mains filter capacitor its only there to stop interference from
the boiler the panel will work OK with out it fitted.
« Reply #14 on: July 21, 2015, 06:36:57 AM »
OK, I took the controller apart on my boiler and took some high resolution pics as below...
The numbers on the outer casing
The rear of the PCB
Closeup of the mains filter capacitor, you will notice that there are some components under it, rectifier diodes and resistors.
the main relay contacts
Mains filter cap from above
The remaining components - a few more caps, some diodes, two transistors and lots of resistors
and finally the whole device from above
It is all real basic stuff electronics wise, all the components should be available and easy to replace.
The transistors do have writing on the can but I was unable to read it with them in situ, you would have to replace one to read what they are.
