Author Topic: The futility of 1u filtering  (Read 9036 times)
« on: May 17, 2015, 04:16:07 PM »
The bio was very foamy pumping into a drum - turns out I'd dipped the pickup into the glyc at the bottom of the settle drum.
See that black layer at the bottom? This went straight through a 1u filter without any issues at all.
Perhaps useful for keeping grit and waxes out of the final fuel, but definitely not soap or glyc!
Re: The futility of 1u filtering
« Reply #1 on: May 17, 2015, 04:24:52 PM »
That explains why I've seen fallout in my stood cubbies then. At least it won't block the filter but not good if it settles in the bottom of the tank.
« Reply #2 on: May 17, 2015, 04:34:39 PM »
I know you like the 20 ltr drums for cold weather acclimatisation, but a bigger storage tank, floating pickup and a dispensing hose would prevent it happening.
That or may the way to go is centrifuging ... where's Nathan!
« Reply #3 on: May 17, 2015, 04:35:56 PM »
No second thoughts that's a lot of glycerin to be dropping out of finished bio.  How about water washing?
Offline Rossey
« Reply #4 on: May 17, 2015, 10:18:18 PM »
Is that why my first wash water is always brown
« Reply #5 on: May 17, 2015, 10:34:50 PM »
Not a commentary on fuel finishing, just pre-tank filtration.
The 25l drums I have to use to carry the 35m from the outbuilding to the car :)
« Last Edit: May 17, 2015, 10:37:22 PM by Tony »
« Reply #6 on: May 17, 2015, 10:51:22 PM »
Yes.
« Reply #7 on: May 18, 2015, 01:38:18 AM »
you need to wash more often, dirty southerner !
« Reply #8 on: May 18, 2015, 05:11:45 PM »
's a bit harsh! ;D
« Reply #9 on: May 18, 2015, 05:14:57 PM »
The level of brownness could well be due to glyc carry over. I'm pretty careful with mine but the first water wash is a dark beige due to soap migration.
« Reply #10 on: May 18, 2015, 05:53:49 PM »
Those who work in a dog food factory should not be throwing thier tripe ;D
« Reply #11 on: May 18, 2015, 05:59:33 PM »
there used to be a video of me online getting a wash in a tripe factory !
(climbing into a big tub of freezing cold water)
had a hot date and no time to go home :-o
« Reply #12 on: May 18, 2015, 07:53:50 PM »
A good looking bitch was she?
Isn't that illegal though?
« Reply #13 on: May 19, 2015, 08:16:08 AM »
Paddy has always maintained that to get the bio to pass all the regs you need to allow it to settle for 72 hours before moving on to washing / settling
« Reply #14 on: May 19, 2015, 03:42:45 PM »
I can undertstand this with dry washing, but with water washing surely the water will remove anything that would settle anyway.
