Author Topic: armoured cable - help  (Read 5927 times)
« on: April 29, 2015, 09:10:54 PM »
hi all does this cable look modern stuff or some old tat? anyone know what armoured cable should look like these days? this supposed to be new???
Re: armoured cable - help
« Reply #1 on: April 29, 2015, 09:19:18 PM »
They're the harmonised colours as in Appendix 7 of BS 7671: 2008, go wild :)
« Reply #2 on: April 29, 2015, 09:21:42 PM »
theres 50 meters for 39.99 thus far... may give it a punt then if that's worth it?
« Reply #3 on: April 29, 2015, 09:25:26 PM »
If it's any help, it's 3ph cable ... or am I teaching granny to suck eggs?
« Reply #4 on: April 29, 2015, 09:26:31 PM »
oh ok, didn't realize, no earth then, its for my new shed.
« Reply #6 on: April 29, 2015, 09:31:14 PM »
On SWA cable the outer sheath is usually used as the earth.  You can buy special glands that grip the strands of the sheath and normally include a tag from which you can take the earth.
« Reply #7 on: April 29, 2015, 09:33:59 PM »
so would that be new cable but doesn't have an earth and its for 3 phase stuff?
« Reply #8 on: April 29, 2015, 09:35:14 PM »
right ok thx
« Reply #9 on: April 29, 2015, 09:40:39 PM »
Have you priced up new stuff? I don't remember exactly now, but the last few times I've heard what was paid for new stuff, I was very surprised at how cheap it was.
A relative bought some last year, and got a real good deal by working builders merchants off against each other.
« Reply #10 on: April 29, 2015, 09:45:07 PM »
Good explnation of terminatig SWA here ...
http://wiki.diyfaq.org.uk/index.php?title=Terminating_SWA
Obviously you shouldn't use 3ph cable for single phase, but IF you were to, I'd say you were best off  using the sheath as earth, the brown as live, put blue sleeving over one of the other cores for neutral and don't use the third core.
... by working builders merchants off against each other.
Ooo, errr!
« Reply #11 on: April 29, 2015, 09:54:59 PM »
I'd just use it tbh.... the copper is the same, just different colour plastic around it :-o
« Reply #12 on: April 29, 2015, 10:44:27 PM »
When I put in SWA I used the shield as earth, but I gather it's good to use three core and use shield and the black for earth, the argument being that then the earth is protected within the shield that way.
I'm sure hifly would have a comment on this!
« Reply #13 on: April 29, 2015, 10:46:08 PM »
Depends on the cross sectional area, what is it?  It doesn't look that chunky from the photos.  Are you using it for garden lighting or running immersions?
« Reply #14 on: April 30, 2015, 06:30:12 AM »
heater/lights/welding etc... most shed activity
