Author Topic: Water in methanol. Is there a fix?  (Read 10410 times)
« on: April 24, 2015, 09:39:21 AM »
I was given 120 odd litres of methanol which turns out to have water in it.
Is there anything I can do that will make it pure & / or usable?
If not, what to do with it?
Re: Water in methanol. Is there a fix?
« Reply #1 on: April 24, 2015, 09:59:59 AM »
Commercial places use (fractional) distillation.  But setting up would cost you more than the meth would be worth.
People have talked about water removing gells before, but ive never heard of the results.
« Reply #2 on: April 24, 2015, 10:01:01 AM »
As for what to use it for - if its not too bad, you could try using it for enriched glyc washes?
DGS will, im sure, be able to advise better.
« Reply #3 on: April 24, 2015, 10:26:49 AM »
Thanks.
I wondered if one of the guys who reclaims methanol could do something with it, but TBH I haven't a clue f the energy cost would make that a non flyer.
It's got to be useful for something other than screenwash.
« Reply #4 on: April 24, 2015, 11:31:48 AM »
mmmm....nothing quite like the sweet smell of poison in the cabin!!
I reckon Julian is on the right line...meth enrichement of the glyc prewash.
Do you know how much water is in it? Have you tested it with a spirit hyrdometer or weighed a sample to find out how pure or impure it is. GL posted up on his website a graph that shows the level of contamination.
« Last Edit: April 24, 2015, 11:35:19 AM by nigelb »
« Reply #5 on: April 24, 2015, 12:10:48 PM »
This is the worst. That bottom line on the hydrometer is .800 so I can't give you a definitive SG reading.
« Reply #6 on: April 24, 2015, 01:36:35 PM »
Hi neisel,
There looks to be a lot of water in that methanol. Without knowing how much it is difficult to advise you. If you send me a sample I will test it for water, probably with the sandy brae. Just PM me if you want to do that. Dave.
ps Just doing a few quick calculations, as long as the water was not more than @ 25% it would still work with a sort of enhanced glycerol pre-treatment, but you would have to ensure that there was a lot of glycerol in the mix (maybe anything up to 50%) so it removed the water when it was drained.
As an experiment you could try; 100 litres of oil, 50 litres (or as much as you've got) of glycerol, 10 litres of wet methanol, mixed with 200gms KOH. After draining the glycerol do a 10/90 to calculate 2nd stage which you would do with dry methanol. I think this would work but it depends on the water content of the methanol.
« Last Edit: April 24, 2015, 01:49:57 PM by dgs »
« Reply #7 on: April 24, 2015, 04:15:59 PM »
This is the chart I was eluding to. If you cant weigh 1lt weigh 100ml and multiply the weight by 10. It should give you a good indication.
http://www.graham-laming.com/bd/methanol_purity.htm
« Reply #8 on: April 24, 2015, 05:09:53 PM »
nigel, the big question is not the water in the methanol, but if leicester will stay in the premiership.
« Reply #9 on: April 24, 2015, 05:45:50 PM »
They are on a good run at the mo  :)
« Reply #10 on: April 24, 2015, 05:54:02 PM »
I used to be a season ticket holder until 2 yrs ago. Got fed up with the cheating. I hope they stay up but the bottom line is...I couldn't care less. Must change my avatar. ;D
« Reply #11 on: April 24, 2015, 06:04:26 PM »
Footballing is second only to smileys ... Nige can I help you change your avatar ... sooner the better in my books.
« Reply #12 on: April 24, 2015, 06:54:47 PM »
I'll change it tonight when I get back...off to Music Fest to see my lad play in his brass band.
« Reply #13 on: April 24, 2015, 07:02:24 PM »
Please please change it to a giant smiley :)
« Reply #14 on: April 24, 2015, 11:06:36 PM »
There we go....all done. ;D
