Author Topic: Frankinpump he go buggerup.  (Read 8156 times)
« on: March 29, 2015, 08:26:52 PM »
Frankinpump started making some rather loud noises the last time I used it.
Removing the pump from my tangle of pipe work, reveled a broken cooling fan.
Oh dear, how do I fix this on a Sunday?  Answers on a post card please.
I've increased the size of most part for added strength given the blades large radiuses at their intersections and extended them to the central boss.  I'm not sure if this will affect the efficiency, but it will make them much stronger.
I'll add a write up on the 3D parts page of the wiki.
Re: Frankinpump he go buggerup.
« Reply #1 on: March 29, 2015, 08:42:33 PM »
And peeps ask why would we need a 3d printer.
I'd have gone for intermediate blades similar to the original ones as well.
All decent pumps have 12 fan blades.
« Reply #2 on: March 29, 2015, 08:59:19 PM »
I did look on Google images to check about extending the blades to the boss and the number of blades seem to vary between 5 and 16.
I have a suspicion that the gap between the blades and the boss may act like a suction port, but we'll see when I get the thing put back together.  As long as it shifts a reasonable volume of air I'll be happy.
« Reply #3 on: March 29, 2015, 09:20:51 PM »
I bet you broke it on purpose just so you could use that damn 3D printer thingy
« Reply #4 on: March 29, 2015, 09:31:01 PM »
Envy and Jealousy, just 'cause you ain't got one.
« Reply #5 on: March 29, 2015, 09:35:06 PM »
I think you may well be right.
« Reply #6 on: March 29, 2015, 09:51:38 PM »
KH is right, any normal person would have just slapped some glue on it, put a jubilee clip around the boss and forgotten about it.
« Reply #7 on: March 29, 2015, 09:58:51 PM »
Well said!
« Reply #8 on: March 29, 2015, 10:29:53 PM »
Well said!
Yes, well said ... I didn't think of that!
« Reply #9 on: March 29, 2015, 11:48:56 PM »
And the pump would vibrate like feck 'cause it'd be so far out of balance.
Don't agree with the Luddites Julian you did the right thing, left to peeps like those we'd still be living in caves.
« Last Edit: March 29, 2015, 11:52:27 PM by Jamesrl »
« Reply #10 on: March 30, 2015, 08:02:44 AM »
Good use of the 3D printer that is.  Now you've got me thinking about replacing the broken plastic fan housing on my dispensing vane pump.
« Reply #11 on: March 30, 2015, 08:11:10 AM »
Dont you start as well! :)
« Reply #12 on: March 30, 2015, 12:08:51 PM »
Give up now, you're out numbered.
« Reply #13 on: March 30, 2015, 12:16:27 PM »
if you were really clever you could profile the blades to a NACA profile based on the speed of the motor. that way it would be running at maximum efficiency resulting in greater airflow thus increasing the available power to the pump by using autodesk virtual wind tunnel.
« Reply #14 on: March 30, 2015, 01:33:42 PM »
Dam, I didn't think of that either.
Mind you the original fan was pretty NACAd in the first place.
