Author Topic: Ebay win.  (Read 6996 times)
Ebay win.
« on: March 20, 2015, 07:34:48 PM »
No, not the mono pumps.  Ill try and convince myself that they would have gone much higher had i have bid...
But this -
http://www.ebay.co.uk/itm/Eberspacher-D4L-/251873879339
The damaged motor would be of concern, were it not for the fact that i have a B4L unit somwhere.  Im assuming (hoping) that theyre the same motor.
My landrover 101 was originally fitted with a B4L (long gone) and i have a D2 (modern one) but that does not run on bio.  Ive heard that the modern D4s do, so i thought id give this ancient D4 a go.
For £25, if it all works out, ill be pleased.  Fingers crossed!
Re: Ebay win.
« Reply #1 on: March 20, 2015, 09:11:34 PM »
Fuel pump alone is worth that  :)
Re: Ebay win.
« Reply #2 on: March 20, 2015, 09:20:45 PM »
Keith,
Are you familiar with them?  I know the B4s were fitted in a lot of VW vans.
Re: Ebay win.
« Reply #3 on: March 20, 2015, 09:59:47 PM »
If you can get it working that's one hell of a bargin.
I assume the controls are there as thats WELL over a grands worth if it is all good, apart from the fan motor.
Re: Ebay win.
« Reply #4 on: March 20, 2015, 10:14:59 PM »
Keith,
Yes, i have a BN4, got a few links to manuals etc if you want them?
Re: Ebay win.
« Reply #5 on: March 20, 2015, 10:17:01 PM »
My (modern) D2 has some sort of microprocessor control panel attached to it, but, i understand, all this does is switch a couple of wires in the loom to get the unit running.  I think the modern units have an ECU within the device as well.
My B4 had a silver box, but, what it had it it, i dont know - it was from the late 70s, so it cant have been too 'custom'.  Pretty sure i can see the silver lump in the photos, kind of between the two end caps, under a relay or connector or something.
I should download the manual again, as it has circuit diagrams in it, IIRC.
I dont believe it to be a grands worth.  Modern D4s fetch about £300 on ebay.  Id guess this is maybe £150 worth, if it were fully working?
Re: Ebay win.
« Reply #6 on: March 20, 2015, 10:18:19 PM »
Keith,
I think i probably still have the petrol stuff on the other computer, but thank you anyhow.
Ill see if eberspachers site has anything for the old D units.
Re: Ebay win.
« Reply #7 on: March 20, 2015, 10:38:26 PM »
I was comparing it to a new one not secondhand.
Re: Ebay win.
« Reply #8 on: March 20, 2015, 11:27:37 PM »
keith did you ever do anything with that d12?
Re: Ebay win.
« Reply #9 on: March 20, 2015, 11:50:13 PM »
Still need the odd bit to finish, i think i can class it as a long term project :)
Re: Ebay win.
« Reply #10 on: March 21, 2015, 01:06:48 PM »
i said that as well. about 15 years ago ;D
