Author Topic: Uh oh - breakers tripped  (Read 8362 times)
Re: Uh oh - breakers tripped
« Reply #15 on: March 16, 2015, 09:18:21 AM »
yep, just connect straight to 12v
I thought the same thing, they're a bit too cheap.... but the 8 I have up are working great, they're not normally on much, but I left them on overnight the first night I put them up to test them a bit... all still perfect in the morning :-)
plus, cheap enough to replace if they go wrong
they used to combine postage, deffo. did the first time I ordered :-(
« Reply #16 on: March 16, 2015, 09:38:42 AM »
Hmm, maybe I've cocked it up. I wanted two different colours, so added them to basket. When I went to the basket, they had got postage on each item. Same when I ordered the four. Couldn't see any way around it.
Not to worry, they are still ridiculously cheap.
I want them for interior lights for two vehicles. Perfect solution for that. No way I could do it cheaper, or better, probably.
I'm sure I can find a whole load of other uses when I get them in my hands.
« Reply #17 on: March 16, 2015, 10:08:48 AM »
I've got some Fluro light fittings banging around somewhere. Installed for about 12 months then removed.
Interested? They're in Somerset - I can probably get them to Southampton sometime in the next few weeks.
« Reply #18 on: March 16, 2015, 02:34:23 PM »
Be careful connecting LED light strip 'just to 12v' in a vehicle. The electrical system may be close to 12v at rest but nearer 14v when charhing and that will start to cook the LEDs.
I ruined some in the caravan till i remembered the mains hookup charger puts out 13.8v float.
A regulated 12v supply to them will make them last much longer
« Reply #19 on: March 16, 2015, 02:52:04 PM »
Tempting, let me think over the options.  The existing fitting was 2x 6ft 75W tubes - 150W total - and replacement ballast is quite expensive.
The alternative is to try 12V LED strips which are 75W a piece, or some mini COB floods (which may also be useful for camping).  Apparently ~20W LED is the same as 75W flourescent.
« Last Edit: March 16, 2015, 02:58:15 PM by Tony »
« Reply #20 on: March 16, 2015, 05:34:27 PM »
Ah, cheers for that. I'll look into it, get a regulator or something.
« Reply #21 on: March 16, 2015, 10:19:05 PM »
If you're looking for LED lights, there are just one one two on this site   https://www.myled.com/
I've had some COB LED strips off them via ebay and the seem reasonable quality.
A 150mm strip @ 3 quid flood lights the printer bed really well.  3 or 4 would light a room.
Despite there massive range I still can't find a 30w led outside flood light with par and over ride ... anyone any ideas?
« Reply #22 on: March 21, 2015, 03:06:01 PM »
Just get a standard pir sensor with override built in and connect a basic 30w led flood to that
Most pir controlled LEDs on our buildings at work are done that way
« Reply #23 on: March 21, 2015, 04:00:05 PM »
Well done Pike, I was wondering who'd be the first to spot that!
Thanks Jules, I should have sussed that out myself.
« Reply #24 on: March 21, 2015, 04:18:56 PM »
the ones I bought have a little driver chip with them
I've had one in the back of a van lighting it up any time a door is open (front or back) for about a year and it's still going strong :-)
« Reply #25 on: April 02, 2015, 06:40:43 PM »
Well I have got those in the link Knighty put up.
Pulled out of the post box at 3.30, fitted a roll in the van by 6.00. (I had to have a snooze before I started.....)
Well chuffed. Flicking them on and off, and staring into them, like a cat licking it's paws after eating a bowl of cream.
I took the power from the original interior light, through a two way switch, so they even work with the doors.
Will test in darkness, soon as nature allows.
They're blue.........
« Reply #26 on: April 02, 2015, 09:07:34 PM »
Hmmm, Blooooo. Very, very Bloooo.
All aboard the Sci-Fi Transit.
« Reply #27 on: April 02, 2015, 10:11:48 PM »
Put it on the roof and make it flash!
« Reply #28 on: April 02, 2015, 11:59:27 PM »
Emergency lawnmowing service, fast response team.
« Reply #29 on: April 03, 2015, 12:41:33 AM »
keeping lawn and order.
