Author Topic: Biodiesel fluorescence with medium powered green laser  (Read 3283 times)
« on: December 28, 2014, 10:26:28 PM »
Thought this might be of some interest - this is biodiesel with 70-100mW of 532nm green.  Attached are pictures of the beautiful orange/yellow fluorescence produced and a comparative photo of the beam brightness in free air (visible thanks to Rayleigh scattering). The fluorescence I did not expect and is surprisingly intense.
I've yet to try 405nm (the beam is a colour that can't be reproduced by a digital camera's colourspace, a mix of blue/violet) but it will be interesting to see if there is a similar effect.
Re: Biodiesel fluorescence with medium powered green laser
« Reply #1 on: December 28, 2014, 11:14:28 PM »
A couple of other shots from tonight :)
What I found interesting about this is that there were flecks of green amongst the orange of the beam - this must be from impurities in the biodiesel.
And a night "breath shot" just for good measure :)
« Last Edit: December 28, 2014, 11:41:21 PM by Tony »
« Reply #2 on: December 29, 2014, 06:21:16 AM »
Somedbody has a new toy :)
Very interesting that the bio glows though - I would not have expected that
« Reply #3 on: December 29, 2014, 06:47:54 PM »
A new toy, ahem, scientific instrument for sure :)
Apparently both organic and mineral oils glow.  According to the wikipedia "Crude oil (petroleum) fluoresces in a range of colors, from dull-brown for heavy oils and tars through to bright-yellowish and bluish-white for very light oils and condensates. This phenomenon is used in oil exploration drilling to identify very small amounts of oil in drill cuttings and core samples."
It must be some property of hydrocarbon chains.
Apparently 405nm (blue/violet) causes peanut butter to glow for a short while after illumination.  Certainly for bio this wavelength is just absorbed with no obvious effect.
« Reply #4 on: December 30, 2014, 04:46:12 PM »
Some new photos:
Even 5mW 532nm produces this fluorescence.
Add a little Methanol and the whole mix turns green.
I'm a little disappointed that 405nm does very little (quickly absorbed producing a lilac colour).
« Reply #5 on: December 30, 2014, 06:29:40 PM »
That is quite fascinating.
Is the laser some kind of pen, that you are shining into the bio, in the dark?
Is there some kind of horizontal layering in the last pic?
Wonder what that is, or is it just the way the container was dried, with a cloth?
I guess with enough experimentation, some useful data about the makeup of the bio must in there somewhere, for testing purposes, and that.
« Reply #6 on: December 30, 2014, 06:57:00 PM »
I know Christmas has gone, but I need a new scientific instrument.
 Seriously though. How are you changing the wavelength and are these what you can shine through to check for soap dissipation.
« Reply #7 on: December 30, 2014, 08:32:03 PM »
If you want a green one, this is where I got the one above:
http://www.ecrater.co.uk/p/21614059/burning-laser-301-green-pointer-flashlight
It's quite the bargain.  The seller is chap in Greece called Chris who is happy to chat about them.  These are overspec so considerably over the 5mW limit - probably about the 70mW mark and easily capable of causing instantaneous permanent eye damage.  Because they use Nd:YVO4 to convert pumped 808nm to 532nm and are quite cheap, there is a good chance of infrared leakage too (no IR filter like expensive green lasers) which is also an invisible eye hazard.
You'll also need a Lithium Ion cell in 18650 form factor (mine are salvaged from laptop batteries) and a suitable charger.  It's best not to skimp on the charger as these cells are very picky about how they are charged (and like to explode if over-charged, or over-discharged).
I have a small collection of these lasers at different wavelengths and powers.
The last photo was a long exposure, moving the beam through the biodiesel.
There are little green flecks which show up in the otherwise yellow beam which I assume are dust or soap molecules.
« Reply #8 on: December 30, 2014, 08:46:40 PM »
Ahh, I can understand the bit about moving the laser.
The rest, I tried running it through google translate, but it wouldn't convert it into HillBilly language.
I think I'll let you do the brains bit, and I'll just look at the nice pictures.  ;D
« Reply #9 on: December 30, 2014, 08:50:54 PM »
Impressive stuff, but I'm working on a much easier way of going blind and it doesn't involve methanol.
« Reply #10 on: December 30, 2014, 09:31:58 PM »
Tosser!
BTW Tony didnt you have a play with a red pen laser, i remember seeing pics?
« Reply #11 on: December 30, 2014, 10:24:21 PM »
Do you have to do that 'cause the tri nostriled one has banned you from the nether regions?
« Reply #12 on: December 30, 2014, 10:59:18 PM »
Tosser!
Yes!  I still do for assessing soap in the water layer of a 50:50 :)
Though now I've got a much more powerful red laser - not quite suited for the task :)
« Reply #13 on: January 07, 2015, 12:14:40 AM »
Diffraction grating arrived today :)
