Author Topic: Leo XKM60 replacement terminal box  (Read 8060 times)
« on: December 18, 2014, 09:15:03 PM »
Finished drawing the terminal box for the Leo this afternoon and just started a print going ... it'll take nearly 4 hours to complete!
These are the 2D screen shots.  I didn't bother with all the fiddly bits the original had on the top face as they would have required support, so its got a nice flat top.
Once it's printed I'll stick up some more photos.
Re: Leo XKM60 replacement terminal box
« Reply #1 on: December 18, 2014, 10:32:50 PM »
4 hours, 4 HOURS!!!!!!
Git y'self a decent printer matey, me i3 is really rapid prolly do that in 20mins.
« Reply #2 on: December 18, 2014, 10:47:50 PM »
If we are facing in the right direction, all we have to do is keep on walking.
Buddhist proverb
That or Matthew 10:24
« Last Edit: December 18, 2014, 10:52:21 PM by Julian »
« Reply #3 on: December 19, 2014, 12:20:58 AM »
Build an i3 and see for yourself.
Old Suffolk proverb.
Oh yeh, I'm printing on bead blasted glass nowadays.
« Reply #4 on: December 19, 2014, 12:36:03 AM »
I'm very happy with what I've got.  I think the belts may need adjustment for the first time since I built it, but it does everything I want it to.
If I've got my sums right, printing in 20 mins what takes me 4 hrs would equate to a print speed of 600 mm/sec!
I considered etched glass when I was building, but blue tape works fine for me.
I think we need some photos of all these new printers, routers and plasma cutters.
« Reply #5 on: December 19, 2014, 01:11:41 AM »
Only took 3½ hrs in the end ... some thing amiss with the printing software me thinks!
It is considerably thicker all round, 3mm vs 2mm on the original and, as with the TAM 120, the screw pillars are integrated into the sides.
« Reply #6 on: December 19, 2014, 08:22:17 AM »
envious -
i have 4-off those leo pumps.  not one of them has an intact terminal cover.
its a shame that its probably uneconimcal for you to sell them, as the originals are so poor that ive never considered it worth replacing them (i think the actual design of the originals is rubbish)
...i realise i still have not replied to your mail on the subject either : (
« Reply #7 on: December 19, 2014, 10:28:16 AM »
Why don't you send the print file to Jim Julian and see how long it takes to print.
And yeah lets have some pics of these printers/routers and the print jobs from them.
« Reply #8 on: December 19, 2014, 11:24:22 AM »
He he ... print wars!
« Reply #9 on: December 19, 2014, 03:19:37 PM »
A bit rough innit, what layer thickness are you using?
If I put the piccies up you'll all knick me mods and advancements and I ain't started on the plasma cutter yet, got the design done but still looking at linear guide rails and bearings.
In anyway n' anyway don't you just love a windup.
« Reply #10 on: December 19, 2014, 04:07:15 PM »
Yes, that's why I think I need to adjust the belts.  It's done 4 Kg of plastic without any maintenance, which I recon isn't bad.
In the true spirit of an open source project ... I'll bet you mumble "Bah, humbug" every time Christmas is mentioned.
« Reply #11 on: December 19, 2014, 06:57:41 PM »
I found that uneven layers was due to the filament rather than belt tension.
I opted to spend a little more on filament and can now print 0.3mm layers with a 0.5mm nozzle upto 70mm/s producing an amazingly smooth vertical surface.
The i3 is a more ridged and prettier machine allowing the greater speeds, well happy with it.
« Reply #12 on: December 19, 2014, 10:51:02 PM »
you going to use rack and pinion or screws to move it ?
I read racks are better normally, and much better for longer axis (I was to be able to cut a 8x4 sheet)
but... the prices I saw for racks were crazy... was thinking I could have some custom waterjet cut for cheaper!
« Reply #13 on: December 20, 2014, 01:29:29 AM »
That could well be the problem.  This filament was quite cheap and from a different supplier to normal.
« Reply #14 on: December 20, 2014, 02:19:06 AM »
There are a few options, cycle chain's,  fixed toothed belt, leadscrew and rack & pinion, I've been looking at leadscrews and SBR16 rails.
As for water jet you'll need some very very serious pressures.
