Author Topic: Soap Titration  (Read 2100 times)
Offline Jeff_Retired
Soap Titration
« on: December 11, 2014, 09:07:53 PM »
Can .01N H2SO4 be used instead of .01N HCl for titrating finished Bio for soap?
Thanks Jeff
Re: Soap Titration
« Reply #1 on: December 12, 2014, 08:03:22 AM »
Yes, it can. Any acid will work - I use vinegar.
Re: Soap Titration
« Reply #2 on: December 12, 2014, 04:00:33 PM »
  That's interesting, how do you dilute it to a known percentage.
Re: Soap Titration
« Reply #3 on: December 12, 2014, 07:17:46 PM »
I use 1 litre per kilo of Kohl
Re: Soap Titration
« Reply #4 on: December 13, 2014, 03:48:27 PM »
It doesn't actually matter as long as you can directly relate a ratio to the whole batch.
So, to titrate 50ml, it takes 1ml vinegar. For 180 litres, it'll then take 3.6 litres. Concentration is irrelevant, it's only ratios.
Re: Soap Titration
« Reply #5 on: December 13, 2014, 09:40:25 PM »
Thanks for the explanation. I can see now that with vinegar being weak you don't need to dilute it to get a reading.
