Author Topic: jelly batch  (Read 12086 times)
Offline zatawitono
jelly batch
« on: October 06, 2014, 04:08:24 PM »
hello guys , this is my first batch
first , i heat up wvo untill 47celcius .
then i mix methoxide that contain 4 liter and 350 gram naoh
after that i put more 12 liter methanol .
mixing around 1.1/2 hour .
then let it separate around 1 hours .
then who knows 1 batch of it become jelly .
question : what cause it become jelly ?
Re: jelly batch
« Reply #1 on: October 06, 2014, 04:15:49 PM »
Almost certainly water, either in the oil, or because the methanol isn't pure.
How are you removing the water from your oil before processing?  Did you do a hot pan test?
http://www.biopowered.co.uk/wiki/Hot_pan_test
Re: jelly batch
« Reply #2 on: October 06, 2014, 05:19:38 PM »
Some jellies can be cracked by adding *more* catalyst and meth, however, certainly not all - so do a test.
If you just add more to the wrong type, it will go from jelly to hard lump.
Offline zatawitono
Re: jelly batch
« Reply #3 on: October 06, 2014, 06:14:45 PM »
this is my jelly batch after  do that process . please give me advise .
thanks a lot .
Re: jelly batch
« Reply #4 on: October 06, 2014, 07:54:54 PM »
What was the feedstock?
Photos look like you have liquid on the top and something quite substantial below.
Offline zatawitono
Re: jelly batch
« Reply #5 on: October 06, 2014, 08:28:28 PM »
The feed stock is wvo.  actually that is no liqiud on the top.  later i use my hand to stir it.  Later i founded that has a liqiud that already mixed up with jelly and the liqiud feels very cool like methanol
Re: jelly batch
« Reply #6 on: October 06, 2014, 08:34:54 PM »
You don't want to be sticking your hand it!!!!
Methanol can be absorbed through the skin ... believe me I know!
Was it all liquid oil with no whites?  You need to get the oil to at least 80 - 85°C and run a venturi and condenser or pump it in a gentle spray (lots of ideas on the wiki) to get it really dry.
As has been said above try reprocessing a small sample.
Re: jelly batch
« Reply #7 on: October 06, 2014, 09:18:45 PM »
That looks like what I made with creamy oil from a Chinese restaurant during my first year of biodiesel brewing.  Resembled turds and was totally unpumpable.  The only batch in years of biodiesel making I didn't manage to recover.
Offline zatawitono
Re: jelly batch
« Reply #8 on: October 06, 2014, 10:10:45 PM »
Thanks for your advise.
So the problem here is.  the wvo has alot water?
No white mean? Sorry i dont get it
Offline zatawitono
Re: jelly batch
« Reply #9 on: October 06, 2014, 10:12:40 PM »
So how you set those creamy oil?  can make it into biodiesel?
Re: jelly batch
« Reply #10 on: October 06, 2014, 10:24:41 PM »
By "whites" people mean nasty creamy oil.  The only way is to boil the water out (it stinks!). I heat my oil to over 100C, but you can do it at a lower temperature with a diffuser - see:
http://www.biopowered.co.uk/wiki/Diffuser
Offline zatawitono
Re: jelly batch
« Reply #11 on: October 07, 2014, 10:25:59 AM »
can i ask now ?
how to clean up this tank ?
thanks all .:)
Re: jelly batch
« Reply #12 on: October 07, 2014, 10:46:47 AM »
Did you get glycerol out before it turned to jelly?
If so...
Take a small amount (1 ltr etc) and add 150ml more methanol, with 3g of caustic added to it (mix the methanol and caustic before additing them to the 1 ltr)
Heat to about 60c, and shake or stir the mixture quite a bit.  Then leave it to stand / cool back to the same temperature as the rest.  Dont keep prodding it, just let it be.
See if the result is a harder jelly, or a 'cure'.
There is no solution without some tests / experiments as not all batches work the same.  You need to test, and find a solution that works - people can tell you the tests, but not what the final conclusion will be : (
Offline rbdazza
Re: jelly batch
« Reply #13 on: October 07, 2014, 10:48:02 AM »
can i ask now ?
thanks all .:)
climb in with a trowel and dig it out, messy business this game..
Offline zatawitono
Re: jelly batch
« Reply #14 on: October 07, 2014, 10:51:50 AM »
can i ask now ?
thanks all .:)
im not sure , that is the solution .
