Author Topic: Oil filled radiators.  (Read 3577 times)
Offline Oilybloke
« on: September 05, 2014, 06:48:36 PM »
You know, the type you plug in to dry your vest, or warm up your y-fronts..........what sort of oil is in them?
Re: Oil filled radiators.
« Reply #1 on: September 05, 2014, 07:56:51 PM »
The kinds of oil that go into the radiator can vary widely, depending on the details of the radiator’s function. Those that pump huge amounts of energy into the oil (like the radiators you’ll find in lecture halls and other large buildings, for instance) need one with an exceptionally high specific heat capacity, most of which are custom-synthesized by chemical companies specializing in organic compounds that can serve as heat reservoirs. Such oils are typically sold under brand names, such as Thermoil or So(i)lstice. Smaller, home-based radiators can typically function with high smoke point vegetable oils, however, and many are designed to work with recycled cooking oils that can be picked up from local restaurants, or distributors that collect from local restaurants for you. This makes for an easy heating solution that’s all at once more efficient and more sustainable than the alternative of water radiators.
With that said, it is important to remember that a lot of the oil filled radiators on the market these days are sealed units that come with their own supply of oil, so you will never need to access it or “change the oil”.
Do you like the way I made that look like I wrote it myself?
I didn't, I copied it.......
http://www.wincoil.com/what-kinds-of-oil-are-used/
Not particularly informative, but it does sound a bit like it could be pretty much any oil.
I wonder how they manage with expansion and that. I know mine has waster in the bottom, coz I hear it popping when I turn it on. If I happen to knock it over, it sound like a deep fat fryer till it gets warm. Kind of suggests that there must be air getting in somewhere. One would have thought that if there is veg oil in it, then there would be some kind of smell, which thinking about it, there is.
« Reply #2 on: September 05, 2014, 10:37:50 PM »
Have no idea what type of oil it is but it smells rancid
brought six faulty Machine Mart radiators in an auction
for the heater elements the oil in them was disgusting.
« Reply #3 on: September 05, 2014, 10:52:14 PM »
Just like those kids coming out of school last month with all those A* plus results in 50 subject ALL copied off the interweb but basically they're as thick as two short planks, the worst part is it's not their fault, it's feckin' polititions setting ridiculous and unachievable targets and dick'ead educationalists fiddling with the results so they can keep thier jobs and feck the next generation of kids.
Offline Oilybloke
« Reply #4 on: September 06, 2014, 06:31:31 AM »
Thank you Greasemonkey.
Jim, I think I agree with you, but don't know if I should.............is it not all about accessing information? I know that we had dictionaries, encyclopaedias, and libraries, but is google just not a faster alternative?
« Reply #5 on: September 06, 2014, 08:52:54 AM »
When my pupils used to do that, for homework etc,  I would print out the origional and give it them that back with a zero mark. Usually made the point, especially when I read part of it to the class to embarrass them. In future at least they would, usually, put it in their own words.
« Reply #6 on: September 06, 2014, 10:47:25 AM »
to be deliberately pedantic, they will also be someone elses words.
when someone accused Paul McCartney of using someone elses chord structure, his reply was "there are 8 notes, sooner or later all them variations will be used up"
same with words. there is only as finite way of describing an item before you start using the same words as everybody else.
plagiarism was fine 50 years ago but with the invention of the internet, with every bit of knowledge shared for all to see, its a bit of an outmoded concept.
dont believe me? get every forum member to PM you with an adjective to describe an apple.
out of 100 replies, 70 would be the duplicated.
« Reply #7 on: September 06, 2014, 12:21:41 PM »
In my rant I didn't mention the main point, it's not where or how they get the information, I used books, it's that they don't have to retain much of it as their homework carried far too much weight towards the qualifications.
We need to go back a few steps eduction wise, learn, retain and apply the gained wisdom.
The whole idea of examinations is to see if the student has succeded in his/her quest for knowledge.
And there are far too many people going on to higher education that shouldn't be there.
I'm also continually amazed at how much the last two generations DON'T know and how limited their maths, English and literacy. Unfortunately I spent 22yrs of my life trying to teach/educate the results of the poor system.
Have a look at the educational standards around the world and see where we as a nation stand.
« Last Edit: September 06, 2014, 12:23:49 PM by Jamesrl »
« Reply #8 on: September 06, 2014, 01:47:06 PM »
thats why im a bit chuffed with my daughters new school.
10 kids to a class and no homework.
the lessons are 100 mins long and the last lesson of every day is a catch up period where each pupil concentrates on whatever they struggled with during the day, with support from university professors to explain the processes.
« Reply #9 on: September 06, 2014, 06:42:01 PM »
And the health service, social services, ect. Its all about perfomance results on paper here in britain
Offline Jmg
    • Veg site
« Reply #10 on: September 06, 2014, 07:43:49 PM »
Don't I just know it I just found the wife with an inch of water across the bathroom floor and the toilet still filling and overflowing, she hadn't shouted on me to cut the water as she was convinced it "would stop soon as it always stops" ??????????????
On paper she's really clever too, just don't look for the common sense part.
