Author Topic: Copper or iron pipe?  (Read 7927 times)
Re: Copper or iron pipe?
« Reply #15 on: September 19, 2014, 11:29:40 PM »
re: brass
isnt DZR brass supposed to be better in chemicals?
Wikipedia -
Quote
Corrosion-resistant brass for harsh environments[edit]
Brass sampling cock with stainless steel handle.
The so-called dezincification resistant (DZR or DR) brasses, sometimes referred to as CR (corrosion resistant) brasses, are used where there is a large corrosion risk and where normal brasses do not meet the standards. Applications with high water temperatures, chlorides present, or deviating water qualities (soft water) play a role. DZR-brass is excellent in water boiler systems. This brass alloy must be produced with great care, with special attention placed on a balanced composition and proper production temperatures and parameters to avoid long-term failures.
No mention of bio and veg oil though.
Offline Soft top
« Reply #16 on: September 29, 2014, 07:57:16 PM »
After 26 days........
From the left,
1. Bio with nothing in for reference.
2. Bio from same batch. Has a very slight hint of green which appeared within 2 days of inserting fitting but did not increase after that.
3. WVO. Went very green within a few days. It looks a bit clearer now but there is green slime on bottom of jar and on the fitting.
4. After my last post (11 days ago) I put a brass fitting into bio from the same batch. No change.
After looking at the samples I am happy to use the copper that I have. The bio that will be standing in the pipes will be from batches with a clear pass and will only sit in the pipes for a max of 2 weeks at a time. It seems that green slime is produced from something in wvo.
Offline rbdazza
« Reply #17 on: September 29, 2014, 08:48:40 PM »
For what its worth I have a mixture of copper pipe and 'plastic' pipe on the bottom of my storage tank which have had bio sat inside them for over a year (obviously the bio is continually refreshed but they are always full) and the bio comes out the nozzle crystal clear still.
Offline slabster
« Reply #18 on: April 19, 2015, 05:50:26 PM »
The main issue of material compatibility is the effect on the product. Worth testing the fuel I think.
Slabs
