Author Topic: bio resistant hose needed.  (Read 3478 times)
« on: August 03, 2014, 07:00:29 PM »
where do i find bio resistant hose? i need around 3 metres of 8 mm and 3 metres of 10mm for the the van. getting someone to drop the tank and change the hoses for me. its a ldv convoy 400 minibus.
Re: bio resistant hose needed.
« Reply #2 on: August 03, 2014, 08:22:00 PM »
I may be wrong, but for vehicle use, I thought the twin wall clear stuff, with a triangular braid in between the two walls was OK.
« Reply #3 on: August 03, 2014, 09:03:41 PM »
Nylon air line works really well.
Used it on the spill lines on the last two Discos.
« Reply #4 on: August 03, 2014, 09:52:56 PM »
and the whole Disco fuel system is plumbed with the stuff from the factory
« Reply #5 on: August 03, 2014, 10:20:05 PM »
... with the exception of the injector spill off pipes.
« Reply #6 on: August 03, 2014, 10:25:30 PM »
10mm is massive, for running bio. I have 8mm from tank to pump, and that seems to be plenty big enough for veg. Bio will be thinner.
And yeah, it's the spill offs that are going to get it first.
