Author Topic: trianco boiler  (Read 9498 times)
trianco boiler
« on: July 23, 2014, 11:04:18 PM »
Re: trianco boiler
« Reply #1 on: July 24, 2014, 06:32:41 AM »
That looks like an electro-oil Inter burner in there - same as I have in my boiler which runs very well on biodiesel
Re: trianco boiler
« Reply #2 on: July 24, 2014, 06:56:33 AM »
I've got a brand spanking new one of those burners, without a pump. I probably ought to buy that, for the pump alone. I won't though.
Re: trianco boiler
« Reply #3 on: July 24, 2014, 07:17:35 AM »
You would do better just buying a new pump - its a danfoss unit, and you can get them new for about £40 ish
If you get a new one, it will be b10 compatible.  If you get an old one, it will probably not last all that long.
Re: trianco boiler
« Reply #4 on: July 24, 2014, 09:53:27 AM »
i wacked in a 99p bid, well ya never know, and I've won it!
Re: trianco boiler
« Reply #5 on: July 24, 2014, 10:12:50 AM »
Oooh well done.  I hope the seller honours the sale.
Re: trianco boiler
« Reply #6 on: July 24, 2014, 12:07:36 PM »
I was thinking it might be useful for a hot tub.
Re: trianco boiler
« Reply #7 on: July 24, 2014, 12:17:34 PM »
I can see it now, a hot tub with 7 different water heating oil burners around the outside, and people being boiled alive in the middle ;)
Re: trianco boiler
« Reply #8 on: July 24, 2014, 12:50:41 PM »
I highly recommend using a boiler as a heat source in a processing plant if anyone gets the chance - running the oil round the water jacket gets it hot really quick.
Re: trianco boiler
« Reply #9 on: July 24, 2014, 01:11:34 PM »
That's what I want one for but a 260 mile round trip was not on
posted on hear for them a bit closer.
I will keep looking one will turn up sooner or later.
What make of boiler apart from the trianco uses the eletro burner.
Re: trianco boiler
« Reply #10 on: July 24, 2014, 01:34:26 PM »
thanks for the heads up Richard.
ooh I didn't think that far ahead James, so that is another possibility then.
Re: trianco boiler
« Reply #11 on: July 24, 2014, 03:38:12 PM »
looking forward to the jet engine afterburner powered one. plus the 6 m67's being finely tuned. if it is too hot for a hot tub we could always use it for scalding a pig or 2.
Re: trianco boiler
« Reply #12 on: July 24, 2014, 09:25:22 PM »
Cheers, I'll have to get one at some point. Ta.
Re: trianco boiler
« Reply #13 on: July 24, 2014, 10:02:09 PM »
Ill look up the part number for you when i remember to do so...
Re: trianco boiler
« Reply #14 on: July 31, 2014, 10:12:15 PM »
With a bit of support in the background from Jules, I have now got the burner up and running on the button, I tried it on bio and it wasn't anymore smokey than on red, but I can play about with different nozzles and pump pressures now I know I aint wasted me money.
