Author Topic: BBB 2015 hot tub  (Read 113304 times)
Re: BBB 2015 hot tub
« Reply #120 on: January 27, 2015, 02:10:50 PM »
i used to specialise in nuclear, biological and chemical detection and decontamination if its any help...
sounds like you're in charge of "chunderwash 2015" then
« Reply #121 on: January 27, 2015, 03:21:09 PM »
oh.
joy.
« Reply #122 on: January 27, 2015, 03:43:23 PM »
Make sure your jabs are up to date.
« Reply #123 on: January 27, 2015, 04:09:35 PM »
Wouldn't it be better just to get him his own 45 gallon drum of water, and light a fire under it?
Someone could bring a block and tackle, we could make an A frame, and lower him into it.
« Reply #124 on: January 27, 2015, 04:48:36 PM »
Why bother filling it with water?  :P
« Reply #125 on: January 27, 2015, 04:53:35 PM »
Good point. Why bother with the drum at all? Just suspend him over a good roaring fire.........
« Reply #126 on: January 27, 2015, 06:47:33 PM »
WHAT???????             and waste all that fat just think how many litre he would make.
Render the old sod down.
« Reply #127 on: January 27, 2015, 10:31:02 PM »
With talk of roasting Chunder over an open fire, for a minuet I thought the Womble had got away with it,
but then I realized you lot are lulling me into a false sense of security.
I know I've not been very active on here of late, but if I'm aloud I'll be be at the 10th bash.
Offline CHUNDER
« Reply #128 on: January 27, 2015, 10:45:43 PM »
MARK of course your atendance is mandatory onece Jamesrl claps eyes on you his dementure and confusion  will clear .
« Reply #129 on: January 27, 2015, 10:59:40 PM »
Mark who?
« Reply #130 on: January 27, 2015, 11:10:20 PM »
Oh dear, Jim's dementure really is getting bad.
Maybe this will help clear out the old grey matter.
Flowery green dress and lipstick.
Mark who indeed.
« Reply #131 on: January 27, 2015, 11:19:49 PM »
Isn't there a Christmas song ... Chunder's roasting on an open fire,
« Reply #132 on: January 28, 2015, 12:05:25 AM »
Offline J.B. Jagworth
« Reply #133 on: January 28, 2015, 05:19:51 PM »
Good project with loads of imaginative ideas mooted. It behoves us to get real if it is to be a success though, so for starters consider the heat input requirement:
2000 kg of water heated from 10 deg C to 30 deg C; delta t = 20
Specific heat of water (from memory) = 4.2 kJ/kg/deg
Heat input = 2000x20x2.4 = 96,000 kJ
My home heating system puts out roughly 40kW of hot gas to a heat exchanger measured at 30% efficiency, so 12kW goes into the water. The burn-time needed would be 96,000/12 = 8,000 sec or 2hr 13 min
To this one should add a bit to account for heat loss from the pool and more than a bit to allow for re-loading the glyc burner a few times. All in all, I reckon half a day should do it.
Perhaps other contending technolgies might try a similar calc (in BTUs if you want to be awkward :-)
David
Offline CHUNDER
« Reply #134 on: January 28, 2015, 05:40:57 PM »
That lot are going to prove Lynda right. "Gatherd together a terific amount of intelect and skill but geting them to work together for a sustained amount of time ???? ."
My coment was "I would sooner try to herd cats "
