Author Topic: gl build  (Read 8276 times)
gl build
« on: April 14, 2014, 09:56:32 PM »
The new gl i'm building, cap 120 ltrs.
Am hoping to have the time to fit sight tube and do a water test this week end. Will then fit pump for condenser, will vist the scrap yard tomorrow to look for a heat ex
comments are welcome
Re: gl build
« Reply #1 on: April 14, 2014, 10:06:15 PM »
We need photos throughout the build.
Try and swap the 90° elbows for swept bends as it will increase you flow rate.
« Last Edit: April 14, 2014, 10:09:10 PM by Head Womble »
Re: gl build
« Reply #2 on: April 14, 2014, 10:21:29 PM »
They are swept bends, hard to see on photos. am having problems uploading pics. I'm keeping them under 200kb but it tells me an error occurred.
Re: gl build
« Reply #3 on: April 14, 2014, 10:28:29 PM »
heres another
« Last Edit: April 16, 2014, 07:45:00 AM by willbuild »
Re: gl build
« Reply #4 on: April 14, 2014, 10:29:31 PM »
Go to tinypic.com
Click “browse”
Find picture to be hosted
Click “open”
Check file type “image”
Click the “resize” drop down box and select “message board 640x480”
Click the green “Upload” box
Follow the “anti spam” instructions
Copy  the IMG code for forum and message boards
Paste the IMG code into your post
Job done!
Re: gl build
« Reply #5 on: April 14, 2014, 10:47:11 PM »
Go to tinypic.com
Click “browse”
Click “open”
Job done!
There's a guide with pictures on the wiki too ...  http://www.biopowered.co.uk/wiki/Posting_photos
Re: gl build
« Reply #6 on: April 14, 2014, 11:21:48 PM »
I didn't know that was there. It seems quite a few on the VOD are having trouble too hence the quick guide I posted. Just passing on my knowledge. I hate to see people stuggle when the process is rather simple.
Re: gl build
« Reply #7 on: April 15, 2014, 12:27:59 AM »
I'd forgotten it was there until I saw your post!  It wasn't linked or indexed anywhere (I blame the gut that put the page together), so I've stuck a link on the main page of the wiki.
Re: gl build
« Reply #8 on: April 15, 2014, 06:48:16 AM »
Nice Processor!  Looks very neatly done and slim-line with the pump tucked underneath like that.
Re: gl build
« Reply #9 on: April 15, 2014, 07:36:06 AM »
Wrapped in thermal blanket then 25mm celotex. cut groves every 10cms so that it would curve.
Am thinking about putting castors on it so that i can move it around.
The two 15mm pipes below the pump are vent and metoxide in, i may re-site them.
Might place control panel at the front just below base of processor.
Re: gl build
« Reply #10 on: April 15, 2014, 10:19:34 AM »
another fan of celotex i see. i am using the same idea on the walls of my yurt. 20cm strips and ally tape to hold it in place. nice build.
Re: gl build
« Reply #11 on: April 15, 2014, 08:34:04 PM »
They are not what most of us call swept bends,
by swept bend I mean one that's pulled on a bender, far less restrictive.
Offline Mickindashed
Re: gl build
« Reply #12 on: April 15, 2014, 09:10:38 PM »
Thats looking tidy. I'd think about putting the control panel and as much wiring as possible up high so they're out of the way of any spills and leaks that might one day happen.
Re: gl build
« Reply #13 on: April 15, 2014, 09:33:17 PM »
I dont have a pipe bender, tried with a spring 3 times and kinked it every time time so went for those (slow bends) bought them online, was disappointed when they arrived i thought they would be more swept.
Re: gl build
« Reply #14 on: April 15, 2014, 09:53:14 PM »
Fitted site tube today put 50lts of water into it and suprise suprise no leaks also added 1 litre of vinegar, i filled it the other day with water (before mounting) and naoh. thought it would neutrlise any acid that might be left.
I also tried the metoxide intake, the venturi drew 3 lts per minute of water with the cubbie on the floor.
Thanks for the tip re tiny pic Julian.
« Last Edit: April 15, 2014, 09:55:06 PM by willbuild »
