Author Topic: very nice rocket strove heater  (Read 10557 times)
« on: February 20, 2014, 09:15:20 PM »
after  reading bretts post about rocket  stove heaters i have been do a bit of reading. they have come on a lot since the last time i looked at them a few years ago. this design looks really good for the coach or a caravan.
http://www.youtube.com/watch?feature=player_detailpage&list=PL01FFC7A3CB99848B&v=4QbTzU-MG5s
not quite a rocket ass heater but should work really well on old pallets. i can get as many as i want in the summer. if fact the local builders merchants are glad to get rid of them. it looks a bit safer than the spike burner.
Re: very nice rocket strove heater
« Reply #1 on: February 20, 2014, 10:20:51 PM »
Just about out of internet allowance, so I'll have to take a look tomorrow when I get some more.
« Reply #2 on: February 20, 2014, 10:24:34 PM »
I did not hear any noise from it?
Our rayburn will happily go into 'rocket'  mode, under the (in)correct conditions - before hearing that, i did not wholly understand why they were called 'rocket' stoves.
« Reply #3 on: February 21, 2014, 11:51:02 AM »
yes i was puzzled about the name as well. my spike heater also goes into rocket mode very easily as well, complete with roaring flames out of the top.
« Reply #4 on: February 21, 2014, 11:50:15 PM »
That looks like a great wood burner an all, but that is not a rocket stove, it's just a wood burner. He's got the wrong idea.
« Reply #5 on: February 22, 2014, 12:16:38 AM »
it has all the elements of a rocket stove, except maybe the extra air input. but the designs for rocket mass heaters i have looked at dont have  an extra air input. they tend to have a vertical feed feedbox and a horizoncal burn tube, which he doesnt have but the basic idea is the same. the insulated riser and the manifold are right. the flue could do with coming out further though. what part do you think is wrong?
« Reply #6 on: February 22, 2014, 07:25:30 AM »
I'm in a bit of a quandary now. He's managed to make it to the plan, but I still think he's cocked it up.
Think of the small wood gas camping stove. The only reason it works is that the initial burn is starved of oxygen, by the top layer of ashes. The wood gas seeps out of the hot charcoal layer underneath, out the holes and up the side, where it is re burned at the top, ignited by the flame on top of the initial burn.
In the rocket stoves, the air is shut down, and carefully managed, to get the initial burn to gassify. If there is too much air flow, it's just conventional combustion. It may get pretty hot, and the draw takes the flame up the chimney, but that isn't the essence of a rocket stove. That's just trying to set the chimney on fire.
The main air needs to be going into the secondary chamber, for sure, to drive the secondary burn, but the initial burn needs to be strangled, to build up a depth of embers. Think of the way they make charcoal, that is what your trying to achieve with the initial burn.
« Reply #7 on: February 22, 2014, 09:59:30 AM »
Blast you Bob, I spent hours on you tube looking at rocket and other stoves last night!
check out user ppotty1 some good experimental burners
http://www.youtube.com/watch?v=vRo6UFAfPIo&list=UUvqnmwAjp2JR9nZ4R-qlUdg&feature=c4-overview
http://www.youtube.com/watch?v=KdDkkKRv4aw
http://www.youtube.com/watch?v=qidct-0z7O4
EDIT:
just found one like the first one I ever made, like this from bricks,
http://www.youtube.com/watch?v=r66jjYdBmg8
my second was cast in a wvo tin from chicken poo and cement using 4 inch fence post to cast the chamber.
we cooked meals for the BBB on it.
http://picasaweb.google.com/floraflossieflo/BBB09?feat=email#5357686910693242242
http://picasaweb.google.com/floraflossieflo/BBB09?feat=email#5357708758488082082
http://picasaweb.google.com/floraflossieflo/BBB09?feat=email#5357681150546193394
« Last Edit: February 22, 2014, 10:22:57 AM by Chug »
« Reply #8 on: February 22, 2014, 12:44:30 PM »
its all bretts fault he started it dad.  hours? i have spent days... and nights, and brought the book as well. the book is a revalation. well worth the 14 quid or so.  google "donkey rocket stoves" for a link to the forum. you can buy the book there. ppotty1 vids are excellent. now if i had a workshop and better access to  scrap metal i would do some of his experiments. a yurt in a muddy field is not a workshop unfortunatley. i used to be able to go down to the dry dock and rummage though thier skips, in the good old days. cant do that anymore . elf an' safety. worried i might cut myself and then sue them or something.
GM  i think there is a bit of confusion between a rocket stove and a gasifier.
the rocket mass heater, which is what that stove is really without the thermal store, works by getting the riser tube really hot, i mean really hot, up to 1200 C on a good design. this burns up all the oxygen and most of the CO as well. the result is the same as a gasifier, total combustion.
 because it is so hot the exhaust can be 30/ 40 foot long with a suitable size exhaust 200mm is a good size. because the riser tube is so hot the draw is enough to put the hot air though 40 foot of tubing. by the time is exits the tubing it is down to 30 to 40 C. al the heat is absorbed in the thermal mass. yes i am going to make one..... just as soon as it stop s raining, and i finish the procesor, and the yurt an the coach and and and.......... check the link for lots of info.
« Reply #9 on: February 22, 2014, 02:59:20 PM »
It's looking that way. It's me with my wires crossed, not him.
One of my great virtues is I never let go of the stick, even when I know I've got the wrong end of it......:)
« Reply #10 on: February 22, 2014, 09:45:23 PM »
I should have said hours spent on you tube looking at burners yet again, whether it's turks, rockets, rocket mass, masonary whatever, ha ha love em all, and built a few small versions meself, never got to rocket mass version just plain ol rocket, weird coincidence today, the bits of wooden fence posts I used to cast me chicken poo cement rocket stove appeared under a sheet of metal I moved looking for something else.
But I'm thinking now along the lines of ppotty1's woodburner style with glass front door, just coz I like lookin at the fire burnin, mesmerising, I've daydreamed many a cold spell away looking in the flames, but I wanna maybe incorporate the design for running on wvo/glyc/wmo/sawdust too, whatever is available besides wood.
like this one
http://www.youtube.com/watch?v=FLcIrrHjdUM
there is a pretty good book here too
http://lockiemartin.wikispaces.com/file/view/Rocket%20Mass%20Heaters.pdf
« Reply #11 on: February 22, 2014, 09:52:34 PM »
Oh yeah, you probably know anyway but worth mentioning for anyone else reading, but the temps these things can get too you need stainless steel preferably, or very thick steel well insulated, thin steel will just get destroyed.
« Reply #12 on: February 22, 2014, 10:38:08 PM »
ernie and erica wisner seem to be the experts, having built 700 rocket mass heaters i would think they know what they are doing by now. their idea is to make the riser tube out of cardboard surrounded by refractory material as whatever you use will melt eventually. standard solid red bricks seem to be the simplest solution.
i know what you mean about stoves. sitting in front of my spike WMO burner at the moment. can see the flames and hear it as well. cant really get much simpler than a cast iron saucepan with a bit of cast flue pipe welded on the top of the lid with a few holes  and a bit of flexy pipe stuck in the top. i am running on red at the moment as it seems to work better than heating oil. less energy but more controllable . as i have to do a 10 mile round trip to get kero it is about the same price as the red comes from just up the road. what i love about it is how fast it heats up in the morning. bit like the old salamanders, but  a little bit safer. at least it has  flue anyway can get the whole thing glowing cherry red in about 10 minutes if i turn the neddle valve right open.
« Reply #13 on: February 23, 2014, 08:33:21 PM »
Chug,
I was under the impression that stainless was not as good as standard steel in high temperature applications?
I dont know, however, if that is with regard to physical strength (which is not important here) chemical stability?
« Reply #14 on: February 23, 2014, 09:45:23 PM »
dunno the science or theory I'm afraid Julian, thick steel and cast iron is ok, but my experience from turk burners is that stainless was much better than double, even treble thickness steel, maybe I had bad/wrong steel, but it slowly burnt away, and I've heard others say they've had similar experience.
EDIT: I had a look at metal melting temps and steel and stainless steel are quite close, but I've collected some fire bricks from an old storage heater for future playing with fire.
« Last Edit: February 24, 2014, 09:12:11 AM by Chug »
