Author Topic: Titration page  (Read 10933 times)
Titration page
« on: November 25, 2010, 07:26:27 PM »
I'll have a bash at titration.  Chug, your theory and chemistry assistance would be appreciated.  I'll post bit by bit if you can check and edit.
Re: Titration page
« Reply #1 on: November 25, 2010, 07:45:58 PM »
No worries I'm good on theories not so good on the chemistry
Have you had a look at the old titration article? may be some help there.
Re: Titration page
« Reply #2 on: November 25, 2010, 09:16:24 PM »
Will attempt to take some photos of the next titration, does mean I need to make a clean tidy space in the shed (Nige has need it, it's a disaster zone in there).
Re: Titration page
« Reply #3 on: November 25, 2010, 09:37:23 PM »
Tony ... it's ok I can do the basic photos, equipment, colour changes etc.  I was after slightly more  complicated stuff like the burette type thing on a stand that some people use.
Re: Titration page
« Reply #4 on: November 25, 2010, 10:55:46 PM »
Yes, along with others.  It will be a day or two before I can get anything posted.
Re: Titration page
« Reply #5 on: November 25, 2010, 11:08:38 PM »
Nige uses a burette i think,sure he would take a pic or two
Re: Titration page
« Reply #6 on: November 26, 2010, 12:20:58 AM »
Thanks Keith, I've PMed him.
Re: Titration page
« Reply #7 on: November 26, 2010, 11:29:39 AM »
Chug ... just uploaded some stuff on titration would you mind giving it a look through please.
Re: Titration page
« Reply #8 on: November 26, 2010, 11:49:08 AM »
Good stuff so far Julian,
I think it needs to be in the plural though as there is more than just one free fatty acid.
Used vegetable oil, on the other hand, will contain Free Fatty Acid(s) in varying amounts largely depending on how, and for how long, it has been used.
Free Fatty Acid(s) play no useful part in the biodiesel reaction and need to be removed. This is done by adding additional catalyst with which they will react to form soap which is removed later as part of the production process.
Titration is a test that simply determines the amount of Free Fatty Acid(s) in the oil
and are you doing just turmeric or wiill you add phenolpthalien too?
Re: Titration page
« Reply #9 on: November 26, 2010, 11:59:15 AM »
Way ahead of you Chug, I just added a bit on Phenolphthalein  ;D
Re: Titration page
« Reply #10 on: November 26, 2010, 12:11:58 PM »
Thanks Chug, changes made.
I had mentioned Phenolphthalein but as turmeric is so cheap and readily available I wasn't going to cover it any further.
Re: Titration page
« Reply #11 on: November 26, 2010, 01:47:19 PM »
I've rejigged all the wanted links to be file links - this takes anyone that clicks them to the Upload page, and they also appear on the http://www.biopowered.co.uk/wiki/Special:WantedFiles page.
IE was [[photo of digital scales]] now [[File:photo of digital scales]]
Re: Titration page
« Reply #12 on: November 26, 2010, 02:10:19 PM »
They were only really there as a memory jogger for me as the page develops and may not be the final file name.  I'll put a note adjacent to each lest anyone else uploads photos, although on current showings that's not likely!
Re: Titration page
« Reply #13 on: November 26, 2010, 06:12:42 PM »
I just realised the turmeric titration article Maud and I wrote wasn't in with the rest of the old cbt files I uploaded, it is now and If you want to use the turmeric pic from in there you can.
Re: Titration page
« Reply #14 on: November 26, 2010, 06:20:47 PM »
Julian/Tony...the photos you requested have now been uploaded. I'm sure you know where to find them.
Also the three missing photos from my origonal draft on "soap" have now been uploaded for insertion.
Kind regards,
Nige
