Author Topic: Compressor switch gone bang! any ideas?  (Read 1774 times)
« on: January 07, 2014, 06:24:02 PM »
Not mine, but any ideas what it is and where to get a replacement?
only writing is on the bottom:-
1979 0KT 1 0
100/285
_________
Re: Compressor switch gone bang! any ideas?
« Reply #2 on: January 08, 2014, 06:11:56 PM »
Dont think its a pressure switch
« Reply #3 on: January 08, 2014, 08:15:21 PM »
What's the circular bit on the top? It looks like a wound spring.
It appears to be two sets of coils. Could it be some kind of electro magnet switch, with the button popped off?
The sort of thing that breaks contact and won't re set by itself when it looses power?
« Reply #4 on: January 08, 2014, 08:21:22 PM »
It has a switch on the underneath which looks like it's controlled by an electromagnet on top? so that sounds close, its out of the motor and  has the pressure switch separate, any ideas on a suitable replacement, this one caught fire but the motor continued running
« Reply #5 on: January 08, 2014, 08:35:06 PM »
Ahhh, so that spring like thing, sat on top, between the two coils, could be a thermostat, that expands, and pushes the switch off, when it gets to hot, killing the motor.
Sort of like a lock out, you need to reset it once its triggered. I suppose it's got gummed up and failed.
I'm just guessing this mind.
Some kind of thermal cutout switch as a replacement then? There must be something on the market. I guess knowing what temperature it needs to cut out at would be the thing.
Could be worth quizzing some of these motor rebuilders. See what they say.
I'd probably just cross the wires and carry on. What's the chances of the motor overheating?
Of course if it's running all day, unsupervised, then that's a different story, but just in a private workshop, it may well be turned off unless it's being used.
« Reply #6 on: January 09, 2014, 02:17:26 PM »
is it not just a fuse/overload ?
thermostat bit sounds right - if the motor is pulling too much power it heats up, expands and cuts the power ?
so any motor overload thing on ebay should do it ?
or just use a D rated MCB which is only just big enough to run the motor... D rated ones are like slow blow fuses so it won;t trip at start up... but if the motor pulls too much power for too long it'll trip ?
or personally... unless it's tripped in the past... I'd just bypass it
« Reply #7 on: January 09, 2014, 05:46:24 PM »
Thanks Knighty & GM i will pass the comments on
