Author Topic: Goldenray machines  (Read 5979 times)
Re: Goldenray machines
« Reply #15 on: December 14, 2013, 08:04:53 PM »
To the best of my knowledge the elements used on those machines are bog standard 2 1/4", it's just the length you need.
Offline Pault19630
« Reply #16 on: December 14, 2013, 08:08:50 PM »
Cheers for this I will check it out
« Reply #17 on: December 14, 2013, 08:14:27 PM »
If you're in the UK currently, it might be worth buying an immersion with the shortest element you can find, just on the off chance.
They are far and away the cheapest heaters of that type available and I can't see Golden Ray fitting anything but the cheapest components to their kit.
« Reply #18 on: December 14, 2013, 08:17:37 PM »
I'd look for an 11" one as that's the smallest, they're still 3kw just shorter.
Also get one for aggressive water as these last longer in bio.
