Author Topic: Emulsion, or not converted?  (Read 5109 times)
« on: December 12, 2013, 03:03:40 PM »
100 litres of real bad oil. Glyc wash, leave circulate for 1 hour, at around 55c. About 10 litres of glyc in. After settling for an hour, drain about 40 litres of muck out the reactor, consistent in quantity with the sample I took.
Add back a further 30 litres of good WVO, so back to 100 litres.
1400ml of ASM, 12 litres of methanol. Circulate for one hour, at above 60c.
This is what I have. No separation, no dropout.
[/URL
Re: Emulsion, or not converted?
« Reply #1 on: December 12, 2013, 03:53:21 PM »
Whites and grotty oil needs really high temperatures (circa 90oC+) to make it usable.  I don't glycerine wash but I'd have treated the bad oil first to get it to a reasonable state added the good oil and then glycerine washed.  If you have any doubts about the oil always do a HPT.
Try taking a sample and whack in a bit more methanol and ASM.  You'll get a reduced yield, but you should get some yield.
« Reply #2 on: December 12, 2013, 04:17:54 PM »
I wasn't really expecting to get that amount of gunk out of the  bad oil after glyc washing. Now, I've pulled about 150 litres out of the reactor into drums, so I don't know what the heck is going on.
I'll do some experiments with it, see what happens.
For some reason, it's now going solid.
« Reply #3 on: December 12, 2013, 04:24:57 PM »
You don't want to leave it too long where it is, the snow will make it even wetter !
« Reply #4 on: December 12, 2013, 04:27:59 PM »
On a serious note you had a reaction with a total of 112 litres and yet you have now drained 150 litres out, am I missing something ?
« Reply #5 on: December 12, 2013, 04:30:31 PM »
Drop it round my place.  You can line it up next to Womble's soap ready for reprocessing.
« Reply #6 on: December 12, 2013, 04:32:44 PM »
I think it's me who's missing something. I'm slowly coming coming to the conclusion that I had far more oil in there than I thought I did. I did my workings for 100 litres, so have one third less chemicals than I needed. That would explain a lot.
It must be unreacted. There was a perfect split after the glyc wash, and i know the oil I added after was hardly used. I hardly think it's an emulsion, the last time I tried this I had the pipe work full of water, and that came out OK.
« Last Edit: December 12, 2013, 04:35:38 PM by greasemonkey »
« Reply #7 on: December 12, 2013, 04:51:18 PM »
It does just look like an unreacted mixture to be fair.
« Reply #8 on: December 12, 2013, 05:03:44 PM »
Try 90/10 and see if it all drops out.
Id have got it hotter too.  I know youre using ASM, but, at this time of year, i run everything on the hot side, as it means that there's less chance of things getting blocked on the settling.
« Reply #9 on: December 12, 2013, 05:12:39 PM »
I'll try a 10/90 and see what happens.
I'll leave it till the morning now.
« Reply #10 on: December 12, 2013, 05:50:47 PM »
Why you no rissen!
The answer to every problem (apart from world peace and why Jim's been banned from the VOD) is to add more catalyst and a bit more methanol.  You can see it's under reacted, I've got 200 litres of under reacted bio sitting in the garden that I've been stairing at for 6 months.
Heat the sample to around 60oC, slowly add  premixed catalyst and methanol whilst string (beware fumes) and watch it change to a lovely clear golden liquid.  But it doesn't end there, no Sir, because as nice as it looks it won't drop any glycerine at this stage ... add a bit more methoxide until it starts to go translucent.  Give it a damn good stir and then leave ... you'll be pleased with the result ... honest.
« Reply #11 on: December 12, 2013, 06:01:46 PM »
Why you no rissen!
In will, don't worry. I'm not so concerned about an emulsion now.
« Reply #12 on: December 12, 2013, 09:47:40 PM »
GM, am I correct in thinking your glyc wash was with just 10% glyc?
If so, that's way too low. it won't remove all the water.
For crappy oil, I'd be looking at using 30%.
« Reply #13 on: December 12, 2013, 09:59:53 PM »
GM, you'd under dosed the ASM and methanol even for a 100ltr batch
You should be looking at 1500ml ASM with 13.5ltr meth, never start with less than 15% of the batch volume of methoxide.
Your sample looks like a lack of chemicals.
« Reply #14 on: December 13, 2013, 09:24:11 AM »
Yes, around 10%. Maybe I ought to leave the worst stuff alone till I build up a bit more glyc.
