Author Topic: New pump  (Read 12636 times)
New pump
« on: December 05, 2013, 10:34:06 PM »
Fitted my new pump this evening.  Managed to integrate it with my spaghetti without too many alterations ... two pipes extended and one judiciously bent.
What a difference.  With oil at 8oC it makes 30 psi at the venturi inlet and 15" Hg at the venturi suction.  I ran it for about 45 minuets and the oil temperature rose to 22oC with no heater!  At 22oC, the venturi produces an amazing 27"Hg.  Running the Mono in series makes little or no difference.  In comparison the old Leo pump didn't even start to move the gauge until the oil was at 40oC and would only make about 12"Hg with oil at 70oC.
It will be interesting to see what difference the new pump makes to my demeth and process times.
Best ten quid I've spent in ages!
Re: New pump
« Reply #1 on: December 05, 2013, 11:19:06 PM »
For those of us who dont read *everything* here - what pump is it?
Re: New pump
« Reply #2 on: December 05, 2013, 11:53:30 PM »
TAM 120 ... 75 lph
Re: New pump
« Reply #3 on: December 06, 2013, 09:17:51 AM »
Whoopi!
Welcome to the bio brewing fraternity, at last.
Re: New pump
« Reply #4 on: December 06, 2013, 09:49:25 AM »
I'm envious.  I have a selection of high pressure pumps and a shiny JRL multi-port venturi to try, and I'm spending my time hanging doors and building stud partitioning :/
Re: New pump
« Reply #5 on: December 06, 2013, 03:44:01 PM »
Come on man, get your priorities in order.
Tell swmdo that you need the plant to make the bio so you can go and get the stuff you need to do the home improvements FOR HER.
AND the doing it for her just might bring other benefits but don't hold your breath.
Re: New pump
« Reply #6 on: December 06, 2013, 04:45:07 PM »
Re: New pump
« Reply #7 on: December 06, 2013, 06:53:35 PM »
TAM 120 ... 75 lph
Ah a tiddler  ;D
How you know he's only got a little one?
Re: New pump
« Reply #8 on: December 06, 2013, 07:20:37 PM »
TAM 120 ... 75 lph
Ah a tiddler  ;D
Word gets around. Not quite ingrowing apparently
Re: New pump
« Reply #9 on: December 06, 2013, 07:46:18 PM »
TAM 120 ... 75 lph
Ah a tiddler  ;D
y
So will he be forever known, from this day forward as Acorn?
Re: New pump
« Reply #10 on: December 06, 2013, 07:47:28 PM »
I have 2-off JGS's 110lpm units in a box under the stairs.  Im looking forward to fitting them on the next rebuild.
(im half way through turning up the coupling plate to fit the both of them, but, as my lathe is 250 miles away, im not making the best progress....)
Re: New pump
« Reply #11 on: December 06, 2013, 07:57:33 PM »
And I thought my workshop was far enough,  18ml.
Re: New pump
« Reply #12 on: December 06, 2013, 10:55:08 PM »
Well well well, finally you've got around to doing something about the underpowered pump (or should I say pumps).
It's not like we haven't tried to convince you to do it, I mean, the first thread I remember of yours was concluded that you needed to either change the pump or unscramble the pipework.
So what can we take from this, some do heed the advice given to then, some take some time to implement it, and some, like Julian, struggle on defiantly for many years before giving in.
Re: New pump
« Reply #13 on: December 06, 2013, 11:29:17 PM »
I do hope your leg feels at least 2" longer than it was before.
Re: New pump
« Reply #14 on: December 07, 2013, 12:07:54 AM »
Bit harsh!
I'd have put a bigger pump on it long ago, but I wasn't going to spend a fortune doing it.  Heather has been sitting in the wings for a couple of years, but she was way too big.
The pump got changed because it came along at a good price the two, inch and a half to one inch reducing bushes I needed cost me nearly half the price of the pump, which I rather resented, but it's up and running for £14.50.
Next you'll be accusing me of slow building work!
