Author Topic: Vod problems  (Read 29745 times)
Re: Vod problems
« Reply #15 on: November 28, 2013, 07:01:55 PM »
Dick I've raised it again on the mod/admin section of the vod forum for you, I'll see what they say
Can you get the login page up ok?
Re: Vod problems
« Reply #16 on: November 28, 2013, 07:13:56 PM »
Thanks chug,
No I can not get past the error screen
Error 503 : Service Temporarily Unavailable
I get this on all machines. I can, however, get into the base site
http://www.vegetableoildiesel.co.uk
The error comes in at
http://www.vegetableoildiesel.co.uk/forum/index.php
At a loss what to do.
Re: Vod problems
« Reply #17 on: November 28, 2013, 07:23:21 PM »
Fuzznag has just registered ok, and I got the reg page up ok so registration is working that end,
can you try from a different location, a neighbour with different ISP? to ascertain if it's a problem specific to you or your ISP?
can you get it with link
http://www.vegetableoildiesel.co.uk/forum/member.php?action=reg
http://www.vegetableoildiesel.co.uk/forum/today.php
EDIT: Dick is there anything on the 503 error to indicate it's from vod forum software?
« Last Edit: November 28, 2013, 07:31:35 PM by Chug »
Re: Vod problems
« Reply #18 on: November 29, 2013, 09:29:47 AM »
mod consensus is it's most likely Zblock,
as bass addict said, it never seems like Paddy knows exactly how this thing works though!?! Or how to unblock IP ranges etc.
Re: Vod problems
« Reply #19 on: November 29, 2013, 12:57:00 PM »
http://wEww.vegetableoildiesel.co.uk/forum/member.php?action=reg
Neither of those links work for me just get the 503 error.
Will try on someone else's system but it will work or are least get me to guest on the site which I can't do on my machines.
Googling the error seems to indicate it is forum end which is also indicated by the fact that I can get into paddy a base site.
I will try a proxy server later and see if that helps.
All ideas great fully received.
Thanks for the help.
Dick
Re: Vod problems
« Reply #20 on: November 30, 2013, 10:31:24 AM »
Yes it seems to be blocking you with forum software, only paddy can sort it nobody else has access to the orum software files.
i'll send Paddy's mobile number to you Dick via PM and you'll have to hassle him to pull his finger out.
Re: Vod problems
« Reply #21 on: November 30, 2013, 03:52:40 PM »
paddy is considering migrating to mybb now.
http://www.vegetableoildiesel.co.uk/mybb/index.php
Re: Vod problems
« Reply #22 on: November 30, 2013, 04:34:41 PM »
Yay I can get into this.
When does he expect to migrate the content, do you know? If it is in the not too distant future I will wat for that.
Thanks for your hep Chug.
Re: Vod problems
« Reply #23 on: November 30, 2013, 06:24:38 PM »
just said he was considering it over in the mod section and posted that link and then started a thread on main forum called MYBB and just said any thoughts?
Re: Vod problems
« Reply #24 on: November 30, 2013, 06:33:31 PM »
mybb is a huge step forward, lots of extensions/plugins - long overdue!
Is there a conversion tool for the database/users?
Re: Vod problems
« Reply #25 on: November 30, 2013, 08:53:30 PM »
I can not get in now [ 509 bandwidth limit exceed ]
Re: Vod problems
« Reply #26 on: November 30, 2013, 09:07:31 PM »
yep, bandwidth error here too, gotta wait til next month now!
Re: Vod problems
« Reply #27 on: November 30, 2013, 09:27:51 PM »
He will be asking for donations next!  ;)
Offline Rossey
Re: Vod problems
« Reply #28 on: November 30, 2013, 09:37:57 PM »
What am i gonna do know, suppose I'll have to talk to the wife  :-\
Offline Jonzeyboy43
    • wasteoilbath.co.uk
Re: Vod problems
« Reply #29 on: November 30, 2013, 10:37:16 PM »
Band width exceeded
