Author Topic: Manufacturing fault  (Read 1110 times)
Manufacturing fault
« on: November 17, 2013, 08:11:58 PM »
Well that was annoying.  Fitted a mixer tap to the kitchen, which came with two flexible tails.
Hot worked, nothing from the cold.
Swapped the cartridges, blew through the tap, all seemed good - but that cold refused to run.
Scratched head for some time.
Found out what it was in the end, it was the flexible hose tail on the cold feed - the threaded end that engages with the tap had a hole down it for the water but they hadn't drilled it all the way through so no way for the water to pass!
Grumble grumble
Re: Manufacturing fault
« Reply #1 on: November 17, 2013, 08:37:19 PM »
at least you didn't have to get a plumber in to sort it out. bet you wouldn't have got his fee back from the manufacturers.
« Reply #2 on: November 17, 2013, 08:44:45 PM »
I had the same thing with what passes for a regulator on my mig welder.  When I first got it all my welds were really, really bad until I realised what the problem was and drilled out the gas port ... now they're only really bad!
