Author Topic: selling pumps  (Read 3660 times)
Offline whatarascal
selling pumps
« on: November 15, 2013, 11:57:23 AM »
Is anyone here selling pumps.
Or would you recommend a pump around 120lpm
One day its all gonna go off
Re: selling pumps
« Reply #1 on: November 15, 2013, 01:16:02 PM »
K.H uses a big Tellarini from this range for his processing:
http://www.tellarini.com/inglese/prodotti2b_ing.htm
I have a couple of them, a little one ENM25 (53lpm) to transfer oil and a brand new big one ENM40 (149lpm) which is "in the collection" but I've not found a use for yet.
They really are beautiful pumps, as they self-prime, are reversible, are ever so quiet in operation and not closed impeller like a lot of pumps of that flow (so less likely to block).
I'm trying to work out if I would be willing to part with the bigger one, since I'm not using it - but you know what it's like, part with it then want to use it for something like building a big processor.
If you want pressure for running a venturi/eductor well then the multi-stage Calpedas are the bees knees - the MHXM range.  Stainless lovelyness and great for pressure, however closed impeller so can block up with lumps in the oil.
http://www.calpeda.com/products/mxh
Do occasionally turn up on eBay.
Offline whatarascal
Re: selling pumps
« Reply #2 on: November 15, 2013, 03:34:07 PM »
I should think the   ENM 40 would be ok for my venturi as I only use it for demething.I suck the methoxide in via processor pump.
The ENM40 looks like far to big a pump than you need  ;D
Offline whatarascal
« Last Edit: November 15, 2013, 03:52:29 PM by whatarascal »
Re: selling pumps
« Reply #4 on: November 15, 2013, 04:32:00 PM »
The Pedrollos are ok, i use to have one on my plant,
BTW my batches are 300lt + thats why the big pump  ;)
Re: selling pumps
« Reply #5 on: November 15, 2013, 05:56:15 PM »
Not a fan of Pedrollos, I have an 80lpm one with brass impeller, I would say it actually shifts about 50lpm and that's with hot bio.
Re: selling pumps
« Reply #6 on: November 15, 2013, 08:17:19 PM »
I've only had one Pedrollo pump, said to be 80ltr/min, it would only run backwards.
The most reliable and consistent pumps I've used are Stuart Turner 903, 80ltr/min (but turns out 90), tremendous flow and pressure.
« Last Edit: November 15, 2013, 08:23:49 PM by Jamesrl »
Offline whatarascal
Re: selling pumps
« Reply #7 on: November 19, 2013, 06:36:11 PM »
Re: selling pumps
« Reply #8 on: November 19, 2013, 07:21:43 PM »
well lets hope this one runs the right way.
http://www.ebay.co.uk/itm/350909442365?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
600ltr/min?
That'll punch a hole in the opposite side of the drum.
Offline whatarascal
Re: selling pumps
« Reply #9 on: November 19, 2013, 07:51:27 PM »
Re: selling pumps
« Reply #10 on: November 19, 2013, 08:58:55 PM »
HFm51B top flow rate is 300lpm but it doesn't have much power behind it (quite a flat curve, low max head) so will be nowhere near that with veg.
Re: selling pumps
« Reply #11 on: November 19, 2013, 11:23:54 PM »
