Author Topic: You can now say "I told you so"  (Read 3413 times)
« on: November 06, 2013, 10:30:29 PM »
Come on then you lot, do your worst with the I told you so.
A while ago I posted about my idea for mist washing overnight and unattended,
well I did just that last night, after a clear 10/90 and 7% water wash.
Tonight I returned to see my tastefull flooring with a nice bio sheen.
I have no idea just how much bio found it's way into the drain but what was left is still a little cloudy in a 50/50 test,
so, as the never overflowing wash tank was working as it should I've left it running overnight again.
Brave or stupid, you decide.
I will get some kind of level switch / float valve on the misting head, maybe some time soon.
Re: You can now say "I told you so"
« Reply #1 on: November 06, 2013, 10:36:47 PM »
On the contrary, I'm sorry to hear of your loss.
Do you know why it overflowed?
« Reply #2 on: November 06, 2013, 10:41:39 PM »
What, no pee taking.
No idea why it overflowed, the never overflowing tank was working when I left it and when I got back.
Offline Bill
« Reply #3 on: November 07, 2013, 07:44:18 AM »
Some while back I tried the never overflowing mist wash (attended!). At some stage well into the procedure the outlet started to clog. I put it down to the cold mist water causing a a thicker waxy/soapy layer that reduced the outflow. I stoppped the mist input but if I hadn't it would have overflowed the processor.
Both sold
« Reply #4 on: November 07, 2013, 07:54:04 AM »
Well I've been doing it for about 5 years now and all outside sometimes in - conditions and it's never overflowed yet, you sure you didn't work out the measurements after a tipple or three? :)
« Reply #5 on: November 07, 2013, 09:38:23 AM »
Keith did you use 22mm pipe or plastic drainage fittings?  Maybe Mark only use 15mm and that's not enough to cope with some thicker components formed?
« Reply #6 on: November 07, 2013, 10:09:34 AM »
Though I don't have a misting tank I'd have thought 32/40mm drainage pipe would be the best bet for the outlet.
Just to keep you happy y'daft sod, TOLD YOU SO. la la la ha ha ha.
« Reply #7 on: November 07, 2013, 10:28:41 AM »
how about using a couple of outlets? have one  a bit higher feeding back into the tank. if there is a blockage the extra head may be enough to clear it.
« Reply #8 on: November 07, 2013, 12:40:44 PM »
When I tried mist washing, I used small bore pipe for the overflow and that blocked but luckily I managed to catch it in time.
What caused the blockage I suspect was the start of an emulsion ... gloopy white stuff.  Probably wouldn't have been a problem with larger pipework though.  If however you do get an emulsion and you're not there, with bigger pipe work you'd loose the lot down the drain.
I tried bubble washing too ... wasn't impressed with it but if you were to use that method, at least every thing would be contained in the tank what ever happened.
« Reply #9 on: November 07, 2013, 06:18:32 PM »
Outlet is 1", for it to over flow it must be a blockage or the water coming in at a faster rate than it can escape, if your worried you can always attach the misting nozzle to a ball cock
« Reply #10 on: November 07, 2013, 06:37:40 PM »
you can always attach the misting nozzle to a ballcock.
Oi, steady on there, that sounds remarkably like common sense.
« Reply #11 on: November 07, 2013, 06:46:17 PM »
Sorry I don't know what came over me
« Reply #12 on: November 07, 2013, 09:22:44 PM »
WHAT ! ! ! HOW VERY DARE YOU ! ! !
« Reply #13 on: November 07, 2013, 09:55:21 PM »
It's just a lot of pussy foot and tipy toeing around.  With pump washing you just slap it in give it a good whirl and drain it ... no messing about.
« Reply #14 on: November 07, 2013, 10:13:42 PM »
Firstly, Jim, thank you, I needed to be told.
Well I've just had another read up on the GL site (something I didn't do before converting my wash tank) and I've made a couple of mistakes,
1, I used 15mm pipe.
2, it's position was guesstimated.
So with all the info available to me I just forged ahead from memory.
Keith, I should have taken you up on the offer of the valve as well as the misting head.
So the concensors is an emulsion was the reason it overflowed, I can see why and tend to agree with this.
On the plus side my new defuser has worked nicely,
on the down side I lost 15 to 20L due the overflowing problem.
