Author Topic: immersion heater not coming on  (Read 3100 times)
Offline alifreddy
« on: October 27, 2013, 11:26:51 AM »
any ideas? switch it on and no heat no visible signs of overload or burnt circuits when take back off heater
Re: immersion heater not coming on
« Reply #1 on: October 27, 2013, 12:08:19 PM »
There's a reset button on the thermostat, it's quite smalland usually next to the temperature control knob.
Offline alifreddy
« Reply #2 on: October 27, 2013, 12:29:57 PM »
tried that is working again something to do with the switch that operates the pump and heater its not clicking to turn on the heater.
« Reply #3 on: October 27, 2013, 12:46:17 PM »
may of burnt switch out is it a high rated switch? due to turning on a 3 kw heater and pump
Offline alifreddy
« Reply #4 on: October 27, 2013, 01:50:16 PM »
the switch is a white box with a knob on it i got it to work again. it operates the pump ok just not turning on the heater.
could it need  a new thermostat
« Reply #5 on: October 27, 2013, 01:53:57 PM »
if you put a test meter on the ends of heater and power is going to it then heater is dead and you have checked reset button also, could be dead yeah try new one
check wiring is still connected all way through to heater
Offline alifreddy
« Reply #6 on: October 27, 2013, 04:33:19 PM »
thanks got it to work. makes a clicking sound when that turns on both pump and heater are operated by one box could bypass the box and make the heater just plug into a socket by a plug but will check first as u said
Offline diggermart
« Reply #7 on: January 25, 2014, 06:53:45 PM »
 I had a problem with mine put muti meter on it {unplugged} heater ok.It was the socket switch contacts that where burnt {arcing}cleaned them now ok.Note to self get a heavy duty one.
