Author Topic: Fat melter  (Read 16097 times)
Fat melter
« on: June 06, 2011, 07:13:07 PM »
I like this:
http://www.biopowered.co.uk/wiki/Simple_fat_melting_and_de-watering_tank.
I take it you sit the tin in hot oil to melt the contents, then pour them in with the mix?  How do you filter the hot oil for BCBs?
Re: Fat melter
« Reply #1 on: June 06, 2011, 11:09:30 PM »
You could use oil, but the intension was to use water, less messy.
I've mostly used it on semi liquid oil that will just about pour, probably a different story in winter.  It heats oil quite quickly, but as stated it does need a stir to get the very bottom hot.  It's left to settle, water drained off and oil skimmed off the top with the Mono via this ... http://www.biopowered.co.uk/wiki/Tips_and_wrinkles#Foot_strainer.
When the oil is more solid, I'm guessing I could heat and settle, drain water and then reheat without stirring, hopefully leaving all the BCBs in the stagnant bottom section.
Great little device for dealing with rubbish oil, I've just got nowhere to put it!
Re: Fat melter
« Reply #3 on: June 08, 2011, 05:42:43 PM »
Ah maybe you should mention it's a water based heater on the wiki page.  Nice idea, I do like that.  I'm getting increasing quantities of solids or semi-solids but no way to handle the stuff at the moment.  Just need to apply heat somehow, and the idea of a water heater appeals - but I'd need one big enough to sit my 60l clip-tops in (or bail them out by hand, eeeeeew)
Re: Fat melter
« Reply #4 on: June 08, 2011, 06:45:59 PM »
It can be either water or oil, depending on what you are doing.
Water is mentioned in the "Using the tank" section, but good point, I agree, it's water operation should be made more obvious at the beginning. I'll change it later if I get a chance.
What's the diameter of your 60 litre drums?
Re: Fat melter
« Reply #5 on: June 11, 2011, 05:20:53 PM »
first post link not showing to me?
Re: Fat melter
« Reply #6 on: June 11, 2011, 05:29:55 PM »
Oo Er, me neither, strange.  Try this one
or the link on the main menu works.
Re: Fat melter
« Reply #7 on: June 11, 2011, 05:31:36 PM »
Nope, weird ... I'll try and suss out why, mean time the link on the main page works ok.
Re: Fat melter
« Reply #8 on: June 11, 2011, 07:21:19 PM »
Ha Ha,bleedin armature
Re: Fat melter
« Reply #9 on: June 11, 2011, 08:14:48 PM »
Ok, ok ... I feel suitably admonished.
It's the full stop.  I'll remove it from the title, no other page title has a full stop ... trust me to screw it up.
Re: Fat melter
« Reply #10 on: June 11, 2011, 08:25:23 PM »
There you go, removed the full stop and the links work.
Now, about this unresolved problem on your processor ...
Re: Fat melter
« Reply #11 on: June 13, 2011, 10:37:59 AM »
I bought one of these:
http://cgi.ebay.co.uk/TRAVEL-HEATER-ELEMENT-WATER-COFFEE-IMMERSION-500w-220V-/270707176206
Actually very impressed, drop into a 60l drum of slops, leave for a few hours and it gets up to a good 60C.  Could possibly even dewater by air bubbling while the heater is on.
Small enough to fit through the hole in a cubie too :)
Re: Fat melter
« Reply #12 on: June 13, 2011, 08:31:00 PM »
Make sure it doesn't touch the sides ... melted cubie ... Exxon Valdez!
Re: Fat melter
« Reply #13 on: June 14, 2011, 12:39:43 AM »
I was worried about that, so I deliberately pressed it against the side of the HDPE drum I was using to see if it would melt in - but it didn't.  I guess the oil around it keeps the element cool enough not to be a problem.
Perhaps that's why kettles are OK, they're plastic but have a heating element in close proximity - so long as they're covered with water all is OK.
I'll try the same with a cubie - if anything is going to melt it'll be that.
Re: Fat melter
« Reply #14 on: June 16, 2011, 09:28:10 AM »
I tried boiling water in a PET bottle and holding the element hard against the sides - no trouble at all.
No good for melting oil that's thick in BCBs though (bottom of barrels) - get bubbles coming up with smoke in them  :o  Burns onto the element.
