Author Topic: Hmm. Black fuel filters.  (Read 5060 times)
« on: September 16, 2013, 01:55:41 PM »
Can't be good - since switching to a 10" filter housing all my filter elements are coming out black.
So I think I may be getting engine oil in the fuel (pump shaft seal giving up maybe?).  That or I've got some form of bio-bug in the tank.
Ho hum happy days...
Re: Hmm. Black fuel filters.
« Reply #1 on: September 16, 2013, 02:02:48 PM »
may just be a dirty fuel tank? these do build up crap
« Reply #2 on: September 16, 2013, 02:05:36 PM »
Had plenty of bio through it so should be OK.
Who is good for 10" filter cartridges these days?  I need to stock up I think!
Edit: These look quite good
http://www.ebay.co.uk/itm/6-x-10-String-Wound-Filter-Cartridge-5micron-Biodiesel-wvo-or-water-filter-/151116706221
« Reply #3 on: September 16, 2013, 02:06:42 PM »
not sure still getting through the ones i got off K.H
Offline whatarascal
« Reply #4 on: September 16, 2013, 04:42:03 PM »
pd110961
does em he is on VOD also sells on ebay in that name
« Last Edit: September 16, 2013, 04:45:33 PM by whatarascal »
One day its all gonna go off
« Reply #5 on: September 16, 2013, 06:10:36 PM »
Tony,
Youre 100% certain youre looking at black (ie engine oil / carbon) rather than almost black / brown (eg glycerol)?
« Reply #6 on: September 16, 2013, 06:11:09 PM »
You didnt use some sort of black rubber hose to plumb them in, did you?
« Reply #7 on: September 16, 2013, 06:43:17 PM »
Could you heat one up and see what runs out. If it is oil, then it should run out.
I'd be surprised though, I wouldn't have thought it would take much oil, and she'd be smoking like a steam train.
Would it be worth running a bit of bio through a pure white cotton cloth, just to see in what way it discolours it.
Could maybe take a sample at different points along the fuel system and do the same thing, see where it is coming from.
« Reply #8 on: September 16, 2013, 07:13:36 PM »
All our fuel filters come out very dark Brown/Black and have done from the beginning of our biodiesel usage.
Don't worry, be happy.
« Reply #9 on: September 16, 2013, 08:13:11 PM »
Most curious Jim. Thanks for the reassurance.
Previously with stock filters I've not been able to see the colour inside, these 10" filters in the engine bay are a novelty to me still!
Yes they are black rather than dark brown. Fuel pipe is all nylon except for a few cm of rubber at the tank end, and between the filter and IP. These were replaced at the point the last filter was changed.  I have used acetone which may also be removing something.
But if Jim has it too I'll relax a bit.
