Author Topic: titration  (Read 3283 times)
Offline alifreddy
titration
« on: September 13, 2013, 01:08:25 PM »
have inherited a lot of testing equipment purchasing a new bio diesel processor. the problem is the tester solution is sodium hydroxide and I use koh how do I convert the results please
Offline alifreddy
Re: titration
« Reply #1 on: September 13, 2013, 01:46:36 PM »
as far as I can gather you take 10 ml of isopropyl solution add 1 ml of oil shake then add a few drops of phenelphalene then count how many millilitres of tester solution you need to add.
« Last Edit: September 13, 2013, 02:24:32 PM by alifreddy »
Re: titration
« Reply #2 on: September 13, 2013, 02:42:00 PM »
remember to blank the fluid before adding the oil.
the wiki will, im sure, tell you more about blanking.
Offline alifreddy
Re: titration
« Reply #3 on: September 13, 2013, 03:11:27 PM »
blank?
Re: titration
« Reply #4 on: September 13, 2013, 03:27:09 PM »
i went to the effort of explaining where you could read more, so why are you asking me that?
Re: titration
« Reply #5 on: September 13, 2013, 03:35:17 PM »
Most seen to have moved away from titrating to using the 'two stage method'. Have a look on the wiki for that.
Offline alifreddy
Re: titration
« Reply #6 on: September 13, 2013, 03:38:02 PM »
saw about 2 staging you start with the base amount then do a 27/3 test. I just want to see how good my oil is got some rapeseed sunflower oil from mc donalds changed every 3 days should be quite good oil
Offline Jonzeyboy43
    • wasteoilbath.co.uk
Re: titration
« Reply #7 on: September 14, 2013, 07:07:38 PM »
How did you manage to get oil from McDonald's thought they had a national contract?????
