I thought about drilling and tapping the hole bigger, but I was worried about swarf falling into the housing
I could probably thread a bit of copper break pipe to fit.. hadn't thought of that :-)
tried 3 local HGV places earlier on but no luck
I think I might just turn them upside down to drill/tap them to a bigger size, then fit some hose to a header tank 6 foot above them and fill it with thin oil...
the grease is more about keeping the crap out of the bearings than trying to lube them... there's water and muck sloshing over them all the time (it's a bit cow stomach washing machine)
guess I might have to pressurise it at first, to fill the housing and push the air out, but once it's full it should take care of itself... unless I drilled an extra hole to fit a bleed nipple for the first time use... which might be the best way to do it...
